Sponsored by:
Sponsored by: CARiD
SSIM 3.5 intake mod
Old Dec 20, 2007 | 04:47 PM
wagesgt903's Avatar
SSIM 3.5 intake mod
So I have been hearing about this intake manifold mod that people have done but cant seem to find anything in stickys about it. I talked to one member about it but was looking to maybe get some pics or more info if anyone had it. Im starting my 3.5 swap in 2 weeks so im hoping to make a decision on whether to run the variable intake or not.
Old Dec 20, 2007 | 05:06 PM
Torgus's Avatar
you gut out the 'shelf' in the Upper Intake Manifold. It adds top and and you lose low end.
Old Dec 20, 2007 | 05:29 PM
00SEMAX19's Avatar
http://www.nissanclub.com/forums/eng...d-results.html
There ya go, Now ya should delete this thread before people start flaming for not searching and being a noob
Old Dec 20, 2007 | 07:09 PM
wagesgt903's Avatar
Dude i searched so i wouldnt be one of those people. But thanks for the site anyway.
Old Dec 20, 2007 | 07:52 PM
spdfreak's Avatar
This mod works best with raising the rev limiter to 7200, using aftermarket cams, and for the motors saftey you should replace the rod bolts with new ones from ARP.
Old Dec 20, 2007 | 08:43 PM
wagesgt903's Avatar
Do you really think the rod bolts are necessary?
Old Dec 20, 2007 | 08:47 PM
spdfreak's Avatar
Yes.
Is it worth the risk?
Old Dec 20, 2007 | 09:23 PM
NmexMAX's Avatar
dot dot dot ...
7100 seems to be safe with stock rod bolts. Anything higher, rod bolts should be mandatory.
Old Dec 20, 2007 | 09:33 PM
00SEMAX19's Avatar
Arn't hte stock rod bolts strong enough for any power that people have put down N/A in our cars? I thought it was only an issue at or above like 350whp.
Old Dec 20, 2007 | 09:38 PM
spdfreak's Avatar
When raising the rev limiter it's reccomended to change the bolts.
Old Dec 20, 2007 | 09:39 PM
nismology's Avatar
Power doesn't kill the OEM rod bolts, revs do.
Old Dec 20, 2007 | 09:40 PM
NmexMAX's Avatar
dot dot dot ...
RB's are more prone to failure due to high engine speeds rather than power levels.
NmexMAX's Avatar
dot dot dot ...
Yours sounded better.
Old Dec 20, 2007 | 09:46 PM
SPiG's Avatar
SomePsychoGuy
I hope you mean VQ.
Old Dec 20, 2007 | 09:47 PM
nismology's Avatar
RB = rod bolts, I'm assuming.
Old Dec 20, 2007 | 09:48 PM
spdfreak's Avatar
Good guess.
Old Dec 20, 2007 | 09:49 PM
NmexMAX's Avatar
dot dot dot ...
Me = the acronym king.
Old Dec 20, 2007 | 09:50 PM
00SEMAX19's Avatar
Lesson learned
Old Dec 21, 2007 | 12:07 AM
accordingtou's Avatar
VQ30 DE T
Oh I thought he meant a skyline engine RB 26/ RB 27 Blah blah blah
Old Dec 21, 2007 | 04:24 AM
wagesgt903's Avatar
I think ill just leave the rev limiter for now. Plus aftermarket cams are way outa the price range for now. Maybe down the road.
Old Dec 22, 2007 | 11:48 AM
NmexMAX's Avatar
dot dot dot ...
In order to take full advantage, an extended rev limiter would help, along with a few other items. 95BLK has done real well with his set-up, and he doesn’t have said limiter extension.
Old Dec 22, 2007 | 01:02 PM
wagesgt903's Avatar
He has the stock limiter? Right now i just want to get it in and running. Once im done i have a dyno that i can use at school so i may try both and see what the numbers look like when a play around with it a bit.
Old Dec 22, 2007 | 01:08 PM
NmexMAX's Avatar
dot dot dot ...
Sure looks like it
What exactly are you planning on doing?
Old Dec 22, 2007 | 03:15 PM
spdfreak's Avatar
Just curious. While reading the thread/link 00SEMAX19 posted I had a question about the SSIM. When the shelf is cut out, do you cut off the VIAS butterfly section of the end cap and use just the end as a cap or is te butterfly left connected?
http://www.nissanclub.com/forums/3140156-post27.html
Old Dec 22, 2007 | 04:56 PM
wagesgt903's Avatar
Sure looks like it
Well i have two intake manifolds so im gonna do one with the SSIM mod and the other with the variable and then put it on the dyno at school. Might as well then we can see what the reall difference is.
Old Dec 22, 2007 | 05:04 PM
Puppetmaster's Avatar
Whatever is easier for you. Some people have made a custom block off plate so they can retain the power valve in case they want to go back to stock. I think Aaron92SE might have one in production so check with him.
Old Dec 22, 2007 | 05:40 PM
00SEMAX19's Avatar
http://forums.maxima.org/showthread.php?t=536022
Old Dec 22, 2007 | 08:08 PM
spdfreak's Avatar
Thanks.
Old Dec 22, 2007 | 09:19 PM
Aaron92SE's Avatar
NWP Engineering.com
NWP Engineering VIAS Removal/SSIM Block Plate
Please see this thread for more information.
Old Dec 23, 2007 | 05:44 AM
wagesgt903's Avatar
Damn that plate looks great. How much do they run for? If its still 35-50 like on the other thread i want one for sure.
Old Dec 23, 2007 | 09:39 AM
95BLKMAX's Avatar
Someone called?
Notice that for some reason, my ECU doesnt even go to the "stock" redline. It bounced off just before 6400 (dunno why, but w/e, ^^ my power curve is pretty healthy)
Old Dec 23, 2007 | 03:55 PM
wagesgt903's Avatar
Ya i dont even see a point it extending the rev limiter when out hp and torque curve start to drop right around 6 grand. But damn i hope i see some numbers like you have when i get done.
Old Dec 23, 2007 | 10:01 PM
95BLKMAX's Avatar
Better gearing for the useless first 2 gears of our 5spd trannies is a reason.
Old Dec 23, 2007 | 10:21 PM
NmexMAX's Avatar
dot dot dot ...
W/ a 4AT, rev limiter extension is a MUST!!
Old Dec 23, 2007 | 11:05 PM
95BLKMAX's Avatar
Old Dec 24, 2007 | 07:58 AM
grey99max's Avatar
LandShark has Cosworth
Not when you spray....... then, monster tires are a MUST !!
Old Dec 24, 2007 | 08:07 AM
Aaron92SE's Avatar
NWP Engineering.com
Thank you. The thread mentions that the expected cost is $50-60.
This plate is made out of a high quality 6061 Billet Aluminum and it's completely CNC Machined with the NWP Logo in raised lettering. Then, the piece is deburred, tumbled and polished to create a flawless block plate. This plate we make is meant for those that care about what their engine bay looks like, which is most 5th & 6th gen Maxima owners.
Old Dec 24, 2007 | 10:37 AM
wagesgt903's Avatar
Mine is a 4th gen but if you can get the plate i would gladly pay the 50 or 60 bucks for it. 95BLKMAX did you ever have the variable hooked up on yours?
Old Dec 24, 2007 | 11:16 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by grey99max
Not when you spray
Wrong forum.
Mine is a 4th gen
Correct me if I’m wrong, but it has a 5.5 gen engine, correct, or at least that’s the plan.
Old Dec 24, 2007 | 11:54 AM
95BLKMAX's Avatar
Nope. Never bothered after seeing all these dynos with stock operating VIs with the drop off on power after just ~5500. Yea thats great for the midrange but... Im more for top end power so I never bothered to get a window switch for it.
