Sponsored by:
Sponsored by: CARiD
Max whp on VQ
Old Dec 23, 2007 | 12:54 AM
  #41
NmexMAX's Avatar
dot dot dot ...
Originally Posted by XAugusta MoonX
That link sucks, no definitive proof found I demand 3rd party dynos.
Old Dec 23, 2007 | 07:31 AM
  #42
chillin014's Avatar
ohh wow. i thought they were half that. damn I was really hoping to stroke it one day too, but 8 grand is something I just dont ever see being able to justify.
there's at least one that i've heard of - that dude that spent like $30k on his altima. dude just threw money at it left and right. absurd to the nth degree.
to get more to the root of your question - because they cost what, $8000 or something? gtfo (not you, the guys that charge $8000 for a displacement increase).
Old Dec 23, 2007 | 08:26 AM
  #43
XAugusta MoonX's Avatar
I realize I'm no expert at this, but I'm liking the N/A idea. I'm just reading along and trying to have as much input as possible. http://www.intensepower.com/aevqstkitg35.html
And info about the kit: http://www.nissanperformancemag.com/june04/aebs/
Old Dec 23, 2007 | 11:49 AM
  #44
505max94se's Avatar
I say put a vq30 crank and rods in it, all bolt-ons, aggressive cams, nismo oil pump, and tune it to 9k rpm...
Old Dec 23, 2007 | 12:41 PM
  #45
spdfreak's Avatar
I thought the HR oil pump was superior to the nismo.
The way to go is DE/HR hybrid. HR pistons, valve springs, double shim, IM, aftermarket cams....
Old Dec 23, 2007 | 01:19 PM
  #46
505max94se's Avatar
Didn't dandymax have an HR pump that he blew up?
I forgot to mention high comp pistons and HR double shimmed valve springs. With the vq30 crank and rods, it will create an 8.5 to 1 compression ratio with oem vq35de pistons. Since this is an NA build, he'll need higher comp pistons.
Old Dec 23, 2007 | 01:38 PM
  #47
DandyMax's Avatar
3.5 in the works
Why would the HR pump be superior to the Nismo?
I don't have an HR pump. Has anyone actually used any bottom end HR parts in a build yet?
Old Dec 23, 2007 | 04:12 PM
  #48
nismology's Avatar
No offense, but this is quite possibly the worst suggestion yet.
Old Dec 23, 2007 | 04:15 PM
  #49
nismology's Avatar
It was a revup oil pump. And its demise didn't really have much to do with its capabilities. An HR pump would have most likely blown up as well in this case.
Old Dec 23, 2007 | 04:25 PM
  #50
DandyMax's Avatar
3.5 in the works
Still not confirmed, guess I should get to that soon.. hah.
Old Dec 23, 2007 | 07:51 PM
  #51
spdfreak's Avatar
Sorry. I made a mistake. I meant the rev-up oil pump, not the HR. What I forgot is that dandymax blew his pump up.
Old Dec 23, 2007 | 08:35 PM
  #52
!PrjctMax!'s Avatar
What about the 4.1 Brian Crower stroker at $5,500?
http://www.briancrower.com/view.php?pn=BC0225
Old Dec 23, 2007 | 11:13 PM
  #53
Nealoc187's Avatar
SLOW
That price is either for a shortblock or just the parts and machine work. That's not a complete motor.
Regular built motors with stock heads and stock cams go for like $6500 for the entire long block.
Old Dec 24, 2007 | 10:23 AM
  #54
!PrjctMax!'s Avatar
So the link that someone posted for $8,100 is for an entire motor with built internals?
Old Dec 24, 2007 | 11:20 AM
  #55
No, actually. It's the block, pistons, rods and crankshaft. Needs oil pan, heads (everything involved with heads) and intake manifolds.
Old Dec 24, 2007 | 11:32 AM
  #56
nismology's Avatar
None of these stroker kits come with anything more than the crank, rods, and pistons (and sleeves if the bore is also going to be expanded).
Old Dec 24, 2007 | 11:36 AM
  #57
NmexMAX's Avatar
dot dot dot ...
Do you know if they affect CR?
Old Dec 24, 2007 | 11:47 AM
  #58
spdfreak's Avatar
If it's built for all motor puposes, I would assume a highter than stock CR.
Old Dec 24, 2007 | 11:52 AM
  #59
NmexMAX's Avatar
dot dot dot ...
Larger bore typically = lower CR, I’m wondering if they ‘compensate’.
Old Dec 24, 2007 | 06:20 PM
  #60
505max94se's Avatar
No offence taken...
Look at the 4th post...
http://www.engineswaptech.com/forums/thread/2764.aspx
I know there is no hard evidence, but this guy seems pretty reputable. BTW, this was achieved on a VQ30 not a VQ32, like I'm suggesting.
Old Dec 25, 2007 | 08:17 AM
  #61
AllBlackMax's Avatar
aka The Doom Ship
It may be easier to get to 280-287whp than 300. I would say(as someone mentioned), find out if your ECU can be reflashed by Technoquare, JWT S2 Cams, IM spacer, smaller pulley, CAI, equal length headers, tuned AFC.
Provided you have LSD and some slicks, you lookin at low 12s, high 11s if you're lucky.
Old Dec 25, 2007 | 08:19 AM
  #62
spdfreak's Avatar
He may not have much room in the already clamped engine bay.
Old Dec 25, 2007 | 08:48 AM
  #63
!PrjctMax!'s Avatar
Why not just get a dyno run with AFR, and send the run-files to TS without getting an AFC?
What did he clamp in there? ............
Old Dec 25, 2007 | 08:56 AM
  #64
nismology's Avatar
No offence taken...
Sick setup, no doubt, but de-stroking a VQ35 still doesn't make any sense IMO.
Old Dec 25, 2007 | 09:02 AM
  #65
Tatanko's Avatar
Bacon Lover
Just my opinion, but that doesn't seem like the best option. It likely won't be as fine tuned and he can't make adjustments down the road if he makes changes. It would, however, save money.
Old Dec 25, 2007 | 09:05 AM
  #66
nismology's Avatar
Sigh......
Old Dec 25, 2007 | 09:06 AM
  #67
!PrjctMax!'s Avatar
True, and I agree with that...but in my case, it doesn't seem as if many tuners would even touch my car...****ers!
So that is probably going to be my best bet, unless Osiris accepts my offer of sending in my spare ECU so that they can test out the UpRev program on a 6th gen
Sigh......
Post #67
Old Dec 25, 2007 | 09:47 AM
  #68
spdfreak's Avatar
The only replacement for displacement is technology.
Old Dec 25, 2007 | 10:53 AM
  #69
chillin014's Avatar
yeah im shooting for between 286.32 and 287.4963horsepower.
Old Dec 25, 2007 | 10:54 AM
  #70
nismology's Avatar
Let's keep it on-topic in here, thanks.
Old Dec 25, 2007 | 10:59 AM
  #71
!PrjctMax!'s Avatar
Old Dec 25, 2007 | 11:08 AM
  #72
spdfreak's Avatar
Back on topic.
Try the SSIM, raised rev limit and rod bolts and see if that satisfies you for now. YOu can always add in a Landrover MAF (iirc 82mm) but you will have to tune for it.
Old Dec 25, 2007 | 11:10 AM
  #73
chillin014's Avatar
lol shhhhh. dont reply to me I dont want it to go off topic.
So...they adjust your timing with the reflashed ECU at technosquare right? how much do they advance it usually for the 3.5 swappers, i wasnt aware they even had reflashes available for us.
Old Dec 25, 2007 | 11:23 AM
  #74
!PrjctMax!'s Avatar
http://forums.maxima.org/showthread.php?t=548792
Post #2
Old Dec 25, 2007 | 11:28 AM
  #75
chillin014's Avatar
Thats for an 02 maxima...not a swapped 95.
Old Dec 25, 2007 | 11:30 AM
  #76
!PrjctMax!'s Avatar
oppsy...
why would it make a difference if it's still the same motor? *flamesuitready*
Old Dec 25, 2007 | 12:00 PM
  #77
spdfreak's Avatar
oppsy...
I will guess. Variable cam timing?
Old Dec 25, 2007 | 12:20 PM
  #78
nismology's Avatar
Enough talk about the TS ECU. It's only for VQ35 ECU's, aka 2k2 and up. Back on the ORIGINAL topic or I will start deleting some posts.
Old Dec 25, 2007 | 01:19 PM
  #79
chillin014's Avatar
Old Dec 26, 2007 | 07:52 PM
  #80
1997 GA16DE's Avatar
Is it really that hard to reach 300whp N/A?
I'm a total noob with VQs but I just pulled 254.9 today, I/H/E and full standalone with a good tune. Granted I plucked the A/C and power steering before I put the engine in.
I'd imagine a set of cams would set me over the 300whp mark.
