Sponsored by:
Sponsored by: CARiD
Where do these lines run to?......
Old Feb 2, 2008 | 07:00 PM
adriena's Avatar
just finishing up the vq35 swap and have a couple questions as to where some of these lines run to....
This line comes from the tranny to.....?
From the coolant bar to ?
These go?
Before i did the swap nissan told me the ecu and engine harness were fried so i got a new ecu and a harness. My car is a 99' and this harness came out of a 97'. The new clip on the harness did not fit into this clip, but i still have the old clip from the original harness that fits. The clip that fits only has 6 wires while the new clip has 8 wires. How would i splice this clip into the new harness so it works?
Old Feb 3, 2008 | 09:15 AM
pmohr's Avatar
No more Maximas...
Number 1, that's a vent tube for the trans, just leave it open.
Number 2, no idea. TB, maybe?
Number 3, the back port is for the brake booster IIRC, and your butterfly plate looks like it was put in backwards or something (is that even possible?). Shouldn't that vacuum line run forwards? Then again that looks rather large, maybe I'm looking at things incorrectly.
For the last pics, consult the FSM for a wiring diagram.
Old Feb 3, 2008 | 09:40 AM
Stabone's Avatar
Picture #3 looks like the place where the previous person ran their IACV into the UIM
Old Feb 6, 2008 | 03:53 PM
adriena's Avatar
not too much help from the FSM for the last picture. All i have is the haynes manuel and it doesn't help with the wire colors off that clip or which wire colors are the same for 95-98 and which are different for the 99s. Anyone care to help that has a manuel that goes more in depth? or know where i can go to find out what colors i can cut and splice together so that it works??
Old Feb 6, 2008 | 05:37 PM
NmexMAX's Avatar
dot dot dot ...
Try this link:
http://forums.maxima.org/showpost.ph...0&postcount=36
Old Feb 6, 2008 | 06:31 PM
nismology's Avatar
The immobilizer info probably just needed to be reprogrammed to the ECU.
Looking up the wiring diagrams as we speak...
Old Feb 6, 2008 | 11:08 PM
adriena's Avatar
yeah thats exactly what i thought but they told me the ecu runs a nads code if thats the problem...i didnt think when its an immobilizer issue it even ran a code for it. just thought the ecu locked up. but the tried everything and wanted me to pay 4100 to fix it so i said forget that ill do it i'm doing a swap anyway.
Old Feb 7, 2008 | 06:26 AM
NmexMAX's Avatar
dot dot dot ...
NATS > nads
Old Feb 7, 2008 | 03:22 PM
adriena's Avatar
yeah that sorry. anyone find anything out about the connector? it the only thing stopping me from being done with the swap.
Old Feb 7, 2008 | 04:14 PM
NmexMAX's Avatar
dot dot dot ...
DL the FSM and go through it.
Old Feb 7, 2008 | 04:23 PM
nismology's Avatar
Ok sorry I lied about doing it last night. But I'm honestly going through the EC section of both FSM's right now and writing down anything that goes through the F36 connector (the brown connector on the engine control harness). I will be posting my findings shortly.
Old Feb 7, 2008 | 05:34 PM
rome06's Avatar
man you are a life saver, we looked and looked through the manual and the wiring diagrams in the back just look completely confusing lol but i really appreciate this !
Old Feb 7, 2008 | 10:08 PM
adriena's Avatar
that link only had maxima years 2000 to 2008
Old Feb 7, 2008 | 10:10 PM
adriena's Avatar
you really are a lot of help i appriciate it all thanks bro.
Old Feb 8, 2008 | 06:26 AM
NmexMAX's Avatar
dot dot dot ...
www.vq35de.com/ESM
Old Feb 8, 2008 | 09:39 AM
nismology's Avatar
Looks like you're going to have to rewire both connectors. Some of the connections that went through the brown connector in 1997 go through the black connector in 1999 (like o2 sensor/CPS (POS)/MAF power, etc). This is gonna take a bit longer than I thought....standby.
Old Feb 8, 2008 | 02:02 PM
adriena's Avatar
okay will do and thanks a ton you dont know how much this is helping us.
Old Feb 10, 2008 | 12:25 PM
rome06's Avatar
did you find out anything new nismology?
Old Feb 12, 2008 | 02:04 PM
adriena's Avatar
find anything out bro?
Old Feb 12, 2008 | 07:02 PM
nismology's Avatar
F36 = brown connector
F37 = black connector
For instance F36-1 = connector F36, pin #1. I will provide the pinouts for both connectors at the bottom.
Turns out most of the connections that need to be moved are irrelevant or redundant. These are the ones that are left to move:
o2 sensor power - Needs to be moved from F36-6 to F37-6. The wire that needs to be moved is red with a black stripe. You will be splicing it into a red wire.
ACRLY (a/c relay coil) - Needs to be moved from F37-6 to F36-6. They will both be black with a red stripe.
Fuel injector power - In a 97 the wiring has the ignition switched power to the ECU and injector power running through 2 seperate wires. The 99 wiring has both going through the same 20A fuse. You need to combine wires 2 and 5 in the 97 F37 connector in this manner: Cut F37-2 and tap it into F37-5, and not the other way around. This will send power to both the injectors and ECU pin #24 through 20A fuse #34.
These wire splices are plug and play as far as retaining the 99 F36 connector is concerned. Just cut them off of the 97 and move them into the same position on the 99 connector:
F36-2 (white w/ black stripe)
F36-3 (light green)
F36-4 (light green w/ red stripe)
F36-5 (white)
F36-7 (red)
These pinouts are on the terminal side of the connector, not the harness side. If you have any more questions feel free to ask.
Old Feb 13, 2008 | 02:54 PM
adriena's Avatar
thanks a lot nismology. after we do that and bleed the clutch were going to try to fire the car up tonight. It probablly wont start because of the new ecu. I was told i have to get my key reprogrammed because of the immobilizer.
Old Feb 13, 2008 | 03:09 PM
nismology's Avatar
What year ECU do you have?
Old Feb 13, 2008 | 04:49 PM
rome06's Avatar
its a 99' ecu
Old Feb 13, 2008 | 08:05 PM
adriena's Avatar
yea 99 fed spec 5 speed ecu. we tried cranking it and it just cranked for maybe a second everytime. tried pulling codes to see if there was a nats code and the scan tool just said error. Is that big or does it just need to be programmed because its a new ecu?
Old Feb 13, 2008 | 08:07 PM
pmohr's Avatar
No more Maximas...
'99, then yes, you'll have to get the key and ECU programmed at the dealer.
Old Feb 13, 2008 | 10:28 PM
adriena's Avatar
and until it gets reprogrammed the car acts like it doesn't have any computer at all and will barely crank correct? and you dont know how much nissan charges for the reprograming of the ecu and key as well i'm guessing because if the immobilizer?
Old Feb 13, 2008 | 10:49 PM
pmohr's Avatar
No more Maximas...
It'll crank, but it won't fire.
Old Feb 14, 2008 | 02:17 PM
adriena's Avatar
okay thanks for all the help especially you nismology
Mar 12, 2020 12:06 AM
spazma7ik
Jan 12, 2017 09:38 PM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
videomano
Sep 8, 2015 03:28 PM
