Sponsored by:
Sponsored by: CARiD
Getting a custom Y pipe made for my Cali Spec 99... O2 sim questions
Old Apr 21, 2008 | 07:28 PM
skuccio's max's Avatar
Beast Mode!!!
Question Getting a custom Y pipe made for my Cali Spec 99... O2 sim questions
I have a '99 SE-L Cali spec, and I just got a Fed spec front header.
I plan on having an equal length Y-pipe made to ditch the Pontiac sound my 2.5" exhaust has, as well as free up some power. But I am confused as to how to proceed with the O2 sensors.
I found the thread where The Wizard talked about how to wire up a sim, but I couldn't follow it. Also, I don't know what sensors I have, or what to replace with sims. I will keep my stock back cat, just looking to ditch the front one(s).
So my question is, what do I need to get, and how do I hook it all up?
Thanks.
Old Apr 21, 2008 | 07:35 PM
MOHFpro90's Avatar
So because you're in cali, you have to run O2 sims for the fronts?
If you make an equal length one, just use your main cat to pass emissions. I wouldnt bother with O2 sims.
By the way, good for you on equal length.
Old Apr 21, 2008 | 08:04 PM
Beast Mode!!!
No, I'm actually in NY.
Cali spec cars, from what I understand, have the regular cat, and a cat in the front header, as well as before and after O2 sensors on all of them.
I am ditching the front header for a Fed spec one to make the custom Y I want and get gains from it. However, I don't want an SES. Hence the need for O2 sims, as the first after sim is made to check the performance of the pre-cat.
Old Apr 22, 2008 | 06:18 AM
NmexMAX's Avatar
dot dot dot ...
I'd PM The Wizard
Old Apr 22, 2008 | 09:54 AM
KRRZ350's Avatar
o2 sims are very hard to come by these days thanks to the epa's crackdown. Your better off getting some bungs welded in after your main cat and extending the wires.
fyi same amount of cat's as on a regular 4th gen, just different set-up for the front one, and the main cat doesn't have a post-cat o2 sensor. Do you have a resonator on your car? No resonator is the first thing that popped into my mind when you said that pontiac sound, just a thought............
Old Apr 22, 2008 | 09:56 AM
NmexMAX's Avatar
dot dot dot ...
Sounds is very subjective, but IMO, seems as if the unequal sound gives the Pontiac / dump truck sound.
I went from a very nice sounding smooth tone, and then to a Pontiac sound by changing my y-pipe ONLY.
Old Apr 22, 2008 | 10:03 AM
MorpheusZero's Avatar
A big to nmex--only good sounding maximas I have heard have been equipped with an equal length Y (I even made a thread about how ****ty VQ30s typically sound).
So the O2s will throw a code if the exhaust hasn't been treated by a cat beforehand? I was under the impression that they were there more for AFR reasons
Guess I need to read up a little more
Old Apr 22, 2008 | 10:13 AM
Also: be sure to post up pics of the final product I am considering going the same route.
Old Apr 22, 2008 | 10:32 AM
Beast Mode!!!
My exhaust sound was absolutely PERFECT when I first got it. However it seems like the resonator is starting to "break in", allowing higher frequencies to get in and make that trademark Pontiac sound...
I like the sound of extending the wires though. I will have to consult my Haynes manual to see what the readings on the sensors are.
Which is exactly why I want to go with equal length. The ****ty stock y-pipe makes for decent sound. If this turns out to be a success I think I will get the shop who makes it to make a batch of them.
Old Apr 22, 2008 | 10:57 AM
I'd PM The Wizard
Always eager to help.
What do you need help with specifically? What don't you understand about my wiring advice/diagrams in that old thread you're referring to?
I bought my O2 sim from Cattman.
For starters, you'll be simulating both downstream O2's. You know which ones are the downstream O2's, correct? You can't simulate the upstream O2's.
Old Apr 24, 2008 | 10:50 AM
If they fit over an LTBII I might be interested...
Old Apr 24, 2008 | 12:40 PM
liqidvenom's Avatar
brotherhood of tq
what is the pontiac sound?
Old Apr 24, 2008 | 12:44 PM
NmexMAX's Avatar
dot dot dot ...
Ever heard an L36 or even an L67 w/ aftermarket mufflers?
Old Apr 24, 2008 | 01:27 PM
Fr33way™'s Avatar
Wild for Width
This is pretty much exactly it.
http://www.youtube.com/watch?v=bwGkY1oeD8U&NR=1
Old Apr 26, 2008 | 06:49 AM
Beast Mode!!!
I don't know/understand the O2 setup my car has, and consequently what I will be replacing.
There are 4 O2 sensors, correct? I know of one before the front cat, and one right before the back cat. Where are the other two, and what am I replacing???
Old Apr 26, 2008 | 04:38 PM
deadlydreamx's Avatar
ur car sounds like that? thats horrible man.. i have a cattman catback and obx shorty headers n ypipe and my car sounds nothign like that
Old Apr 27, 2008 | 04:04 PM
Fr33way™'s Avatar
Wild for Width
Is that what my post says? Going to go ahead and assume that your reading abilities are on par with your typing skills....
Old Apr 27, 2008 | 04:17 PM
nah my bad i was referring to the op.. guess it does seem like i was talkin to you
Old Apr 27, 2008 | 06:02 PM
liqidvenom's Avatar
brotherhood of tq
that honestly sounds pretty nice. it sounds better then alot of the raspy maximas i have heard before
Old Apr 27, 2008 | 10:44 PM
goldtooth's Avatar
Can someone link to The Wizard's O2 sim writeup?
Old May 1, 2008 | 10:00 AM
Correct, you have 4 O2 sensors. Two on each bank. The easiest way to determine and learn about the O2 sensors is to check out the FSM. The FSM shows the location of all four of them. Or, you can pop your hood and look for them, and get under the car to see the hidden ones. After you locate all four, take note of which ones are upstream and downstream. You can only simulate the two downstream O2's.
You are not replacing anything. You are connecting the two dowstream O2's (which are dangling loose) to the simulator. I ziptied the dangling downstream O2's to the center support under the engine, then put some heavy duty double sticky tape on the back of the O2 simulator and stuck it to the the center support as well. I placed the simulator and O2 sensors out of harms way and in such a way that elements like water, rocks, debris can't get to them.
Some other food for thought. Since you're having a custom ypipe made, you could have the welder add some extra bungs for the O2's and you can avoid the hassle/headache of wiring in the O2 simulator.
Old May 1, 2008 | 10:01 AM
I believe this is what Skuccio was referring to....
http://forums.maxima.org/showthread....3178&highlight
Old May 1, 2008 | 07:05 PM
Beast Mode!!!
Yes but wouldn't I get an SES? I was thinking of doing that too.
Old May 2, 2008 | 03:05 AM
Nope. You won't get any CEL's.
Just curious, why do you think you'd get a CEL with this approach????
Old May 2, 2008 | 04:08 AM
Beast Mode!!!
I thought the downstream O2s were there to validate the effectiveness of the pre-cats. If there are no cats, they get the same readings as the fronts = SES light. But if not I will def. just do that.
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
iflexsteel
Sep 2, 2015 08:04 AM
