Sponsored by:
Sponsored by: CARiD
ECU pin diagram for a 99
Old Apr 22, 2008 | 03:02 PM
adriena's Avatar
Does anyone know where to find a pin diagram for a 1999 ecu. I am trying to convert my 99 computer to a 96 computer to do away with my immobilizer and to also be able to use an aftermarket ecu.
I am am also looking for the diagram for the clips that go into the dash harness, as well as connectors for the fuse boxes under the hood.
I am purchasing a 96 engine harness and ECM, and I'm trying to make this as easy as possible before i do this.
Thanks.
Old Apr 22, 2008 | 04:21 PM
pmohr's Avatar
No more Maximas...
Well EC108-115 has the FSM version, but like I said, it's not completely correct.
Assuming F36, F37, F102, and F104-109 are the same, then it shouldn't be a problem.
Now that I look at it, F108-109 are for the TCM, so those aren't relevant.
Old Apr 23, 2008 | 05:45 AM
KRRZ350's Avatar
Here's a list of everything that is on the '99 that isn't on a '98 and vice-versa, this doesn't really help you in any way since you are swapping harness', but I'm posting it anyways. The '98 one might be missing some because it wasn't based on the diagram, only that stupid chart. The are also missing 46/44 for cps.
1999-
17--Immobilizor
35 & 36-- egr volume control valve
53* swirl valve
57* rear o2
68 - a/t comm.
105* rear o2 htr
* = cali
1998
6 - a/t diag line
11 - fuel pump relay
22 - p/n switch
27 - evap purge #2
65 - a/t signal 4
66 - a/t signal 5
73 - a/t signal 1
74 - a/t signal 2
77- a/t signal 1
103 - egrc selenoid valve
110 & 118 - Evap canister purge volume control valve
114 - evap canister purge control selenoid.
Old Apr 23, 2008 | 08:47 AM
adriena's Avatar
So what connectors will be different when i try to swap the 96 harness into my 99?
AaronL
Nov 15, 2020 11:52 AM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
beerman1378
Sep 8, 2015 02:19 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
