Sponsored by:
Sponsored by: CARiD
96 maxima SAFC wiring problem
Old Jun 21, 2008 | 01:57 PM
mastercoryd's Avatar
Hey, i bought a used safc off of my friend and went to wire it up and i was using this diagram... http://www.dynomagic.com/images/diag...0SAFC%20II.jpg. Well, i finally got everything wired up followed the diagram directly and seemed to be fine, i put my ignition on the ON position all my other lights lit up, but the safc itself doesn't turn on or anything it just seems to be dead. So i unplugged the harness itself so when i do try to start it, it doesn't save as the other person's AFR. So i go to start up my car and it sounds like its gonna start it does that ch ch ch ch noise but doen't start? So i hooked up a volt meter, the battery is runing 11.8 which seems ok, and the wire going to the ECU is only reading .4 which is less then half a volt? what could cause this, this would be a reason it's not powerful enough to light up the safc and make my car run, BUT my interior lights and all of that **** turn on? PLEASE help, keep in mind i don't know to much about wiring so explain it simple to me, my uncle does stuff like that for a living and he's the one that helped me wire it, thanks alot!
Old Jun 21, 2008 | 03:35 PM
gtr_rider's Avatar
192.168.1.1
Recheck all your wiring and make sure that both the power and the grounds are installed on the right wires.
Old Jun 22, 2008 | 08:27 PM
i30dvr's Avatar
double check the maf wire going to the afc. Make sure you had completely cut it, not spliced into. I had the same problem with mine.
Lakersallday24
Nov 7, 2024 07:31 PM
kjlouis
Nov 24, 2018 06:09 AM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
bassmann
Aug 3, 2015 07:53 PM
