Sponsored by:
Sponsored by: CARiD
95 Max need help with Vafc
Old Oct 4, 2008 | 09:29 PM
93altima's Avatar
Turbo 4th Gen
Well i look at the write up followed it step by step and well idk. i got the Grey wire from the vafc to pin#23 and on the vafc its showing 100% the whole time and i spliced the MaF pin #54 to the vafc with the Yellow being closer to the ecu and it was like i didnt have no maf i coudnt rev past 2500rpms
Heres my layout:
Vafc1 ECU
Blue Pin # 50
ReD Pin # 67
Orange Pin # 67
White (closer to the ECU) Pin # 54
Yellow (closer to the ECU) Pin # 54
Grey Pin # 23
Green TAM Screw on the back of the cluster
Black Pin # 55
Brown (closer to the ECU) Pin # 55
I have the settings on 6cylinder tith the thr. going up
Old Oct 5, 2008 | 05:23 AM
t6378tp's Avatar
Turbo 3.5
Heres my layout:
Vafc1 ECU
Blue Pin # 50
ReD Pin # 67
Orange Pin # 67
Grey Pin # 23
Black Pin # 55
ok I am looking at the pin layout cheat sheet and why are you using pin 50 and 55
also what do you mean closer to the ecu when using pin 54
you need to cut the maf wire ([pin 54)and solder 1 end to the controller and take the other end and solder it to the other wire on the controller
Old Oct 5, 2008 | 06:36 AM
wirelessdude04's Avatar
always solder wires espeically when it deals with your ECU.... Not having good contact with a wire can lead to bad readings etc.
Old Oct 5, 2008 | 07:01 AM
KRRZ350's Avatar
Ome of those isn't right, they can't both be closer to the ecu. Also, when you say spliced, do you mean intercepted/cut? It needs to be an intercept not a tap. IIRC the maf out wire goes closer to the ecu but I can't remember the colors off the top of my head.
Old Oct 5, 2008 | 09:10 AM
93altima's Avatar
Turbo 4th Gen
the blue pin is on the 02 sensor
and yes i cut pin 54 for the maf
Old Oct 5, 2008 | 09:11 AM
93altima's Avatar
Turbo 4th Gen
sorry thats a typo lol yellow is closer tho the ecu white is on the other end and i did cut the maf wire completely
Old Oct 5, 2008 | 09:13 AM
93altima's Avatar
Turbo 4th Gen
i didnt want to solder yet i wanted to make sure the afc is good
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
