350z intake manifold on 5.5gen, pics inside...
Old 11-06-2008, 09:47 PM
VqMoNsTeR's Avatar
Finally got around to getting my welds done. i made it work with some modifications but i did it . no dyno as of yet but soon.... soon as i get some money. not sure if im the first but ill find out from the post below...
VqMoNsTeR is offline
Old 11-06-2008, 09:55 PM
MaximaSpd85's Avatar
i *think* meximax has something like it....cool nonetheless.
MaximaSpd85 is offline
Old 11-06-2008, 10:22 PM
NiZMo1o1's Avatar
Jime is running the MREV2 , and above name mention.
I will be doing mines in a few months
NiZMo1o1 is offline
Old 11-06-2008, 10:26 PM
ajcool2's Avatar
Not the first on a fwd vq35 but I believe you are the first 5.5 gen. Do you have a spacer and how does it compare to the fwd IM?
ajcool2 is offline
Old 11-06-2008, 11:56 PM
95BLKMAX's Avatar
good job man! tune the sucka and dyno!
Which IMs did you get? regular or rev-up? (FYI to anyone that does not know, the two ARE different in the LIM and the lower clamshell AFAIK. Revup has shorter runners for better breathing up top)
95BLKMAX is offline
Old 11-07-2008, 12:14 AM
QUEENZ CRAZIEST
NYC_VQ30DE-KT's Avatar
How big is the power gain? Is the power curve more smoother than the stock manifold? Looks good.
NYC_VQ30DE-KT is offline
Old 11-07-2008, 12:45 AM
No more Maximas...
pmohr's Avatar
It's about damn time you put those bolts to use
You should go with the AAM spacer, good gains. And no, not biased (well I am, but it's against them).
pmohr is offline
Old 11-07-2008, 04:17 PM
VqMoNsTeR's Avatar
don't have a spacer yet. im still debating. it barely fits now lol.
its the regular one.
no dyno as of yet but it feels better mid range and top end. i had the ssim on before so the lack of low end is normal to me. track event is this sunday so ill find out if it was worth it...
Old 11-09-2008, 06:36 AM
Puppetmaster's Avatar
And for people who need visual aids:
Non-Revup left, Revup right.
Puppetmaster is offline
Old 11-09-2008, 07:53 AM
Turbo 4th Gen
93altima's Avatar
OOOOOOOOOHHHHHHHHHHH ok nice post!! lol
93altima is offline
Old 11-09-2008, 11:25 AM
Zack342's Avatar
did you have to modify the hood?
Zack342 is offline
Old 11-09-2008, 11:49 AM
HotshotVQ35's Avatar
did you go to the track? times?
HotshotVQ35 is offline
Old 11-09-2008, 01:21 PM
Turbo'd Saab
DrunkieTheBear's Avatar
you don't need to if you use the LIM from the 350z as well
I'm gonna try this with my 3.0....I'm gonna try and use the revup lower and the kinetix top half.
good job my Friend
DrunkieTheBear is offline
Old 11-09-2008, 04:20 PM
nismology's Avatar
Using the 350z LIM is not optional; it's a must. But even if the port spacing wasn't different (which it is), both the FWD and RWD LIM's are the same height so that wouldn't make any difference.
Using which LIM?
nismology is offline
Old 11-09-2008, 07:59 PM
Turbo'd Saab
Using which LIM?
you'll see Pics wednesday
Old 11-09-2008, 09:11 PM
a.k.a. STuNtMAN
JonBlz's Avatar
good job buddy
JonBlz is offline
Old 11-10-2008, 07:33 AM
VqMoNsTeR's Avatar
i did have to modify the hood. took off the padding and cut out the support beams in the middle. i had to move the harness in the middle and take the bolts that hold the fuel rail to the firewall to flip the fuel dampener upside down so the throttle body would bolt up. once i got the upper plenum welded there was no turning back lol.
went to the track but wasn't satisfy with my times. but it is my fault. im too broke to afford a tune and new spark plugs before the deadline. but tax season is coming so that will be my last trip to the track N/A...
Old 11-10-2008, 07:59 AM
Is the hood clearance issue because of the TB? I would think the way around that would be to weld on an aluminum tube angled slightly downwards from the upper plenum, maybe about 4-6" long, and connect the TB a little farther down. This is as opposed to putting the TB at the highest point of the plenum.
Did you have any issues rerouting/relocating the vacuum lines? Specifically, the EVAP canister solenoid line and the one line (can't remember) that used to go to the back of the elbow?
Old 11-10-2008, 05:47 PM
nismology's Avatar
Great job! However, I'd be very surprised if a spacer-less standard 350Z IM is any better than an SSIM up top.
Old 11-10-2008, 06:13 PM
SpooledVQ35's Avatar
Your not the first to do it but congrats.
Now put on a spacer...
SpooledVQ35 is offline
Old 11-11-2008, 09:15 PM
ghostmax301's Avatar
time for a hood scoop. Here, i took the liberty of finding you one
Hey, if you made that manifold fit, Im sure this Moose-tang hood should be a breeze fabbing up on your car lol
ghostmax301 is offline
Old 11-13-2008, 01:52 PM
hacim105's Avatar
If I recall correctly, haven't the few people that have done this mod shown that without the 350Z cam timing maps, the 350Z IM is outperformed by the FWD IM (in particular with the SSIM mod)?
hacim105 is offline
Old 11-13-2008, 02:19 PM
nismology's Avatar
If you're referring to Meximax's dyno, he didn't have CVTC at all. The default cam timing that most 3.5 swaps run is good for mid-range power. This also happens to coincide with where the FWD VI is it's happiest. The OP's car actually has CVTC, so let's see what happens before drawing conclusions.
Old 11-13-2008, 03:08 PM
hacim105's Avatar
Well meximax was part of it but I was looking more towards Jime.
I was thinking he never thought the 350Z IM was all that great, but after some research I found he did see an improvement in his track times and grew to like the 350Z IM better.
He went from a 12.489 @ 109.34 with the 3.5 IM, to a 12.48 @ 111.09 with the 350Z IM. And then was able to do even better by adjusting the CVTC.
So theoretically there should be gains with the 350Z IM.
hacim105 is offline
Old 11-13-2008, 03:17 PM
so does this mean that 3.5s with 3.0timing would be better off with the SSIM rather them the 350im?
Old 11-13-2008, 03:28 PM
VQ35 FTW
mastercater7's Avatar
Or even with just a block plate depending on your set up
mastercater7 is offline
Old 11-17-2008, 12:41 PM
ajcool2's Avatar
Interesting.
ajcool2 is offline
Old 11-29-2008, 12:36 AM
khantalha+'s Avatar
nice .. waiting for the dyno
khantalha+ is offline
Old 12-03-2008, 01:28 PM
cw96's Avatar
I installed a 350 intake on my 3.5 swap and on the dyno I went from 258 to 274Hp.Also gained a lot of torque but I can't remember the number of the top of my head. I had the kinetix intake on instead of the ssim though. I'll post my new dyno numbers later .One thing I did do with the 350 intake was I cut off where the 6 bolts in the middle of the intake were.I ground the inside of the top half of the intake smooth then welded up the holes.I did put the spacer on so I had to run around town like a redneck with my hood off and the intake pipe and filter sticking out.I did get into the 13's with this setup on street tires and a 250 lb. passenger with me the last time I was at the track.Only got to do 2 runs because it was so crowded so I did not get to test the new setup out any better. Car was very loud with this setup. Even with my exhaust cutout open you could hear the intake sucking air.
cw96 is offline
Old 12-03-2008, 02:31 PM
ajcool2's Avatar
Wow 270? I'm interested in the graphs. Also could you post up your timeslips? What other mods did you have?
ajcool2 is offline
Old 12-04-2008, 07:36 AM
cw96's Avatar
My graphs are on the dyno computer at the shop. Just need to load them to my computer and down load when i can remember.When I'm at the garage I'm turning wrenches from the time I get off work 6PM until way late in the morning so I don't think about posting my graphs unless I'm killing time surfing on the org.The 350 z intake made a huge difference from the kinetix.I wish I had a ssim manifold to install and compare 350 z manifold on the dyno.What surprised me is how much torque I gained. I expected to actually lose torque not gain it.Of course with dyno run files everyone thinks I'm talking out my butt so I'll have to make sure to get them up but this setup definitely flows a lot more air and worked very well with my cams and some tuning.My time slip is listed and I said I got into the 13 just but with an extra person,street tires spinning, and just figuring out the shift points on the car but that's for another section. i will say this that past 6600rpm I thought the 350 intake would pull like mad to red line but it had the same flat line to the 7200 rpm cutoff as the kinetix hence figuring out the shift points of the car and getting faster times at the track.I would love to see someone run boost with the 350 intake and I seriously thought about it but I've decided to move on to other projects and have started selling off parts of my car to other members on the org.
cw96 is offline
Old 01-15-2009, 03:14 PM
m_turner_02's Avatar
I hate to bump this thread, but has anything else happened with this???
m_turner_02 is offline
Old 01-16-2009, 09:39 AM
VqMoNsTeR's Avatar
sorry fellas, haven't been on the org lately. im planning on getting my utec with this good ol tax return money next month. should have it dynoed and tuned by then...
Old 01-21-2009, 06:45 PM
nismology's Avatar
How much did it cost you to have the upper modified?
Old 01-30-2009, 06:44 AM
VqMoNsTeR's Avatar
100 bucks
Old 02-08-2009, 07:07 AM
VqMoNsTeR's Avatar
news update: just ordered a AAM plenum spacer. should have utec this week!
Old 02-08-2009, 07:54 AM
datdude20's Avatar
the manifold barely fits now......u gonna need a cowl iduction hood...lol
datdude20 is offline
Old 02-08-2009, 11:23 AM
No more Maximas...
pmohr's Avatar
AAM spacer FTW.
Just remember, don't tighten down the middle plenum bolts too much. If you do, you're going to crack the upper half, and then you'll have to get it welded or a new one modified.
pmohr is offline
Old 02-08-2009, 03:50 PM
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
sparks03max's Avatar
Make sure you get graphs when you get tuned with the UTEC.
sparks03max is offline
Old 03-12-2009, 09:00 AM
Play with my balls
Deckdout2's Avatar
In for whatever updates you may have VQ.
Deckdout2 is offline
Quick Reply: 350z intake manifold on 5.5gen, pics inside...
