Sponsored by:
Sponsored by: CARiD
Ignition Timing Problem
Old Jan 14, 2009 | 12:55 AM
whlimi's Avatar
I have a weird issue with my ignition timing under partial throttle.
I datalogged my timing using the EU and noticed that my timing was dropping down to anywhere between 0 degrees and 10 degrees advance anywhere between 7-60% throttle. I have no codes that would point to a problem with ignition timing. This problems is also intermittent. When this condition is present and I try and accelerate, the motor just makes a sputtering sound and a serious lack of power is evident. I'm leaning towards a bad CPS sensor (maybe both). I have no codes for them and I was wondering if anyone else had any suggestions. I dont have hard start problems. I dont have a knock sensor code. What could cause such a huge retard in timing considering that its happening anywhere from 7% to 60% throttle. I dont think its a misfire because acceleration, even though it's horribly slow, is smooth.
Old Jan 14, 2009 | 09:19 AM
KRRZ350's Avatar
Does it only happen with the eu in place? If so, are you comfortable enough with wiring yet to leave the patch harness in place and jump the injector & coil pins, I'd like to rule out the patch harness, in particular one of the ground wires on it, or just interference in general. Also, I kept searching for you and dug up the rest of my wiring stuff, so I can tell you which wires on the 4-cylinder eu harness were used for inj&coil's 5 & 6 in & out.
Otherwise I would think it was a tps or maf issue ftr.
Old Jan 14, 2009 | 11:07 AM
MDeezy's Avatar
i agree. trouble shoot section by section. first rule out whether its the EU's doing or something else. test sensors with a voltmeter to verify its still putting out the correct voltages it should be.
Old Jan 29, 2009 | 05:53 AM
whlimi's Avatar
I replaced the TPS and calibrated it and now it seems to run a lot stronger under light to moderate throttle. The only thing is I had to set the TPS to around 0.2V at idle.
I have this thread in the 4th gen section concerning ignition timing at idle with big cams.
http://forums.maxima.org/4th-generat...on-timing.html
Just wanted the input of those who are running aftermarket cams.
Old Mar 23, 2009 | 10:28 AM
whlimi's Avatar
I have since removed the patch harness and wired everything directly to the main harness but I'm still getting the sputtering at part throttle and ignition timing dropping to low teens. I ruled out the KS buy hooking it up to the firewall. I swapped the 3.0 coils in place of the 3.5 to see if it was a coil issue and the symptoms are still present. The only thing left is MAF or ECM.
Could a dying maf present those symptoms without throwing a code or going into fail safe mode? The worst part is that the problem is intermittent and no codes...very frustrating.
Old Mar 26, 2009 | 11:36 PM
whlimi's Avatar
It seems the ABS/TCS unit was responsible for the retarded timing. I had P1320 because of the EU (no resistors ) and the TCS module didnt like that and lit up the SLIP/TCS OFF lights. I unplugged the module all together and the car runs fine now. Any thoughts as to why it would cut fuel, indirectly retarding timing? I confirmed by plugging in the TCS unit again and the symptoms returned immediately. So right now I have no ABS/TCS but car runs fine
Old Mar 27, 2009 | 06:30 AM
SleepyMax1's Avatar
I wonder if that could also be a problem too... I have th ABS light on, on my swap. No EU thou. I'll found out today.. good info
tsi6001
Oct 3, 2022 10:23 PM
Matt93SE
May 24, 2019 02:58 PM
trasmadean
Jan 20, 2018 05:05 AM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
