Sponsored by:
Sponsored by: CARiD
3.5 coolent line plug?
Old Apr 6, 2009 | 06:58 AM
95stillenmax's Avatar
what is everyone using to plug the coolent line for the 3.5 oil pan application
Old Apr 6, 2009 | 12:08 PM
chillin014's Avatar
i'm curious as well. I think on mine I've got a bolt in the end of a hose
Old Apr 6, 2009 | 12:30 PM
happy4444's Avatar
im confused what you guys are referring to. the only line that flows coolant near the pan is the oil cooler line near the pan... and why r u pluging them?
Old Apr 6, 2009 | 12:49 PM
I was reading some of the forums and I read that when you use the 3.5 oil pan there is a coolent line somewhere you have to plug
Old Apr 6, 2009 | 01:13 PM
happy4444's Avatar
i didnt plug any coolant lines and i used the 3.5 pan in my swap. theyre probly referring to the oil cooler on the filter that has coolant running through it. if you dont use the oil cooler (idk why u wouldnt) u would have to plug the line
Old Apr 6, 2009 | 02:26 PM
grey99max's Avatar
LandShark has Cosworth
Well, if you're using traction bars you can't use the 3.5 pan, 'cause the filter sticks out way too far for that.
Old Apr 6, 2009 | 05:55 PM
chillin014's Avatar
its easier to use the 3.0 oil pan and I dont think you can use the oil cooler with that pan. I forget why exactly people prefer to use the 3.0 pan, i believe to prevent some sort of interference with a cross member or something.
Old Apr 6, 2009 | 07:37 PM
grey99max's Avatar
Something about how the rear crank sensor on the 3.0 pan lines up with the 3.0 flywheel, I believe..
happy4444's Avatar
hmm...i had no interference with cross members either. the only benefit is that the hole for the lower crank sensor for the flywheel is dead on insead of shaving down the pan by guesstimating
Old Apr 6, 2009 | 07:38 PM
happy4444's Avatar
lol u beat me to it by a few seconds grey
Old Apr 6, 2009 | 07:48 PM
chillin014's Avatar
Ahh, i was mistaken. I thought i remember reading that too but thought that it was something to do with the 6 speed swap. How big of a deal is shaving down the pan? Do you just do it until the motor starts/gets a reading or how does that work?
Old Apr 6, 2009 | 08:10 PM
happy4444's Avatar
shaving down the outside of the pan isnt bad at all. i used a grinder and it came out fine. in no way can u use a file unless u have 45+ min to kill lol.
as for the sensor..
the sensor usually fits in the hole but it can be moved around if it doesnt line up w the teeth on the flywheel. i adjusted mine to one side by shaving down the plastic bolt hole on the sensor itself.
check that the sensor lines up w the teeth when the motor and trans are out of the car so u dont have to shove ur head near the rad to see if it is close... i had to do this and it sucked lol
Old Apr 6, 2009 | 08:20 PM
chillin014's Avatar
thanks. ehhh. that sounds sketchy to me. Not saying it cant work perfectly fine, but I wouldn't do it to someone else's car unless they wanted me to. I'm surprised you cant just use the 3.5 sensor.
Old Apr 7, 2009 | 04:05 AM
Jime's Avatar
Shaving for the sensor is a lot easier than swapping the oil pan. You do use the 3.5 sensor if you do an ecu swap but if you keep the 3.0 timing stuff the sensor is shorter thus requiring the shaving.
I don't know why more people don't go the full ECU route, I think its easier than doing all the timing equipment swap. The variable came timing does make an appreciable difference to the bottom end power. Can you say 1.58 60' in an auto.
Old Apr 7, 2009 | 06:23 AM
any pics of sensor setups ?
Old Apr 7, 2009 | 07:29 AM
chillin014's Avatar
wiring can be intimidating. I didnt see a very thorough write-up for this route otherwise I would have considered pursuing it more. I still may in the future though.
Old Apr 7, 2009 | 08:36 PM
happy4444's Avatar
^same thoughts. i felt like if i went and rewired everything to that extent on my 4th gen, i was better off just buying a 6spd 3.5 5th gen. i decided to use the emanage ultimate instead. hopefully everything works out...
Old Apr 7, 2009 | 08:53 PM
chillin014's Avatar
Yeah....I like the idea of it all, dont get me wrong... I just dont find it worthwhile. I want to do an EU as well. Let me know how yours goes. Lets see near 300 whp!
Old Apr 8, 2009 | 04:08 AM
Jime's Avatar
Eng92 (Dave) has some pretty good pics and excel spreadsheet on how to do the wiring. The stuff on the engine is very simple, just connects to all the existing stuff and no swapping injector connectors. Inside the cabin the ecu connector just connects to the ECU. Its the dash stuff that takes a little time but I just did one wire at a time, it went pretty easy.
The other HUGE benefit is using the UTEC vs the EU, direct control over the timing (not piggyback), seamless rev limiter raise etc etc. Having the variable timing is also a huge benefit.
Believe me I did it the 3.0 timing route the first time and then decided to change and then it WAS a big job having to do both at the same time. Bit the effort was worth it for the bottom end benefit.
Old Apr 8, 2009 | 06:54 AM
chillin014's Avatar
damn. I think in the future if I am to do it, I'll just buy another 3.5 unmodified and sell the one I got. Its a possibility though...
Old Apr 23, 2009 | 09:22 PM
tommyd426's Avatar
What about the EGR valve?
When replacing 3.0 (1997) with the 3.5 engine, what is being done with the EGR valve setup. I have only seen one swap where the intake manifold was modified to accept the the EGR valve setup from the 3.0 motor.
What is everyone doing here? If you are not placing the EGR system on the 3.5 motor I am wondering if State Inspection Stations are looking for these components during emissions checks. Any driveability issues or fault codes when not using the EGR system?
Old Apr 24, 2009 | 01:56 PM
pmohr's Avatar
No more Maximas...
If you absolutely wanted to use EGR, you could get the A34 UIM, it has provisions for an EGR setup.
Depending what ECU you have, the lack of EGR equipment will not result in any stored DTCs or failed readiness monitors.
If you're doing a full swap, no need for EGR (assuming A33B donor); the same effect is accomplished using varying CVTC maps.
Old May 5, 2009 | 04:59 PM
tommyd426's Avatar
Anybody else have any advice
Thanks for your input I am using the stock 97 computer and harness and the motor is a 3.5 out of a 2002 Maxima. Does my 97 computer have maps that can be modified?
I'm guessing I will have to modify the intake manifold and EGR tube to mate together somehow.
Questions that remain:
  • Any other solutions out there?
  • Does omitting the EGR cause fault codes?
  • Anyone pass emissions with the EGR system disconnected?
Old May 5, 2009 | 05:41 PM
pmohr's Avatar
No more Maximas...
What do you mean in 'maps that can be modified'? Fuel/timing maps? You'd need a piggyback or a modified ECU.
Again, depending on what year ECU you want to use, you may or may not get EGR fault codes. Get a '95 Fed spec ECU if you want no codes for virtually anything.
You can pass emissions with no problem without any emissions components, as long as:
  1. You're a '96 or greater, and
  2. You have no CEL or failed readiness monitors
Old May 6, 2009 | 04:33 PM
happy4444's Avatar
im currently trying to get rid of as many codes as i can to pass inspection. its a pain in the @ss bc i did a 5 speed swap at the same time. gonna throw in the 96 5 speed ecu and hopefully my 6 auto trans codes will leave me alonneeee
howardis
Dec 11, 2019 06:10 PM
Fbana41
Aug 29, 2016 12:18 PM
doctorpullit
Dec 12, 2015 09:39 AM
zmcneely13
Sep 26, 2015 02:26 PM
