Sponsored by:
Sponsored by: CARiD
fpr problems with 3.5
Old Apr 19, 2009 | 01:08 PM
95stillenmax's Avatar
http://memimage.cardomain.com/ride_i...0078_large.jpg I set the fuel system up like this but my FPR has Three nipples one on each side and one on the bottom I pluged the one on the bottom and hooked it up just like this please help because im ready to try this baby out
Old Apr 19, 2009 | 05:25 PM
also is there a inlet and an outlet on the fpr or does it make a differance
Old Apr 19, 2009 | 07:36 PM
Jime's Avatar
Yes there is an inlet and outlet, the 3rd was probably the gauge port. Did you not get any instructions with it or is it the stock one?
Old Apr 20, 2009 | 07:29 AM
[QUOTE=Jime;6991284]Yes there is an inlet and outlet, the 3rd was probably the gauge port. Did you not get any instructions with it or is it the stock one?[/QUOTE/
its aftermarket and I already have the gauge port used for a gauge and it didnt come with any instructions
Old Apr 20, 2009 | 07:32 AM
Jime's Avatar
[quote=95stillenmax;6991894]
Looks like its going to be trial and error then.
Old Apr 20, 2009 | 07:38 AM
I figured out that the bottom is a return, do I use it or plug it and also Im guessing that the left is the inlet and the right is the outlet
Old Apr 20, 2009 | 07:39 AM
KRRZ350's Avatar
Is there possibly 4? 3 normal and one tiny gauge outlet? That's how the aeromotive's are. On those, you block off one of the inlets (Side ones) and the bottom one is the dump (return).
Old Apr 20, 2009 | 07:40 AM
KRRZ350's Avatar
hehe, looks like you almost havee it figured out, the side ones are both inlets, you will probably want to go back to the T setup and block off the other inlet.
Old Apr 20, 2009 | 07:45 AM
yes thats exactly right, it has 4 including the gauge I will have to switch one of the side nipples to the bottom also I am trying to just test start it without the y pipe is this ok without back pressure and all
also I have the iavc sensors hooked up but dont have a long enough hose to hook it up yet so I taped up the end of it for now just so that I can test start it should this pose any problem
-ReLLiK-
Apr 29, 2016 06:25 PM
Maximan190
Dec 16, 2015 06:01 AM
MaxRPM6
Sep 11, 2015 06:56 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxboy23
Sep 4, 2015 06:04 PM
