Add-to-sticky Request
thanks. I grounded mine out today and went for a short drive, I think I just might feel an improvement! I have tampered with my TPS which I believe is going bad however so the car is acting differently due to that as well. I'll get a new one and see how it feels.
I can drive around with it like this and not worry about anything, right? I have a wb02 w/ a gauge so I can watch my mixture if that is the only fear.
I've done the resistor mod and haven't seen any difference either on the butt dyno or with my scantool. What's really crappy about the 4th gen ECU is how much it pulls the timing in the midrange. With WOT around 3500rpm, I only have 13-16* of advance whereas below and beyond that, I have 23-25*. I need a dam* EU. Maybe part of the problem is how freaking pig rich I'm running. At times, the STFT on both banks is -25% and I'm running the 4th gen FPR w/vacuum. The LTFT is usually around 9-10%.
KRRZ350 mentioned somewhere that running FP at 32-34psi at idle with vacuum hooked up can result in AFR at or near 13s at WOT.
What I could do when I find some time is run the car with the dynolicious application for the Iphone. I'll do a before and after on the same road at the same time and see if the application can pick up the difference.
I will also log 60-100mph times on the EU and see what kind of difference in times I might get.
How are you running with no TPS? I have tried driving with the TPS unplugged and it runs like garbage.
According to the FSM page EC-82, a TPS circuit malfunction (P0120) causes the ECU to go into fail safe mode. I have a 97 5spd and when my TPS was malfunctioning, I couldn't start my car unless it was push started. After it got started, it wouldn't rev past 1500rpm.
Its funny how all these cars behave differently. I wish there was some kind of consistency with these 3.5 swaps.
I would notice this timing "increase" at partial throttle acceleration, right? Ever since I grounded the sensor the car has felt excellent even in 5th gear at 25% throttle and less. The throttle response is great, its like the bogging and hesitations are gone entirely. I cant imagine how it must be for those who can increase timing past stock via the EU.
All depends on throttle position, MAF voltage, and RPM. 40* is nothing at small throttle openings. 40* at WOT at low RPMs would kill the engine. The mixture burns at a uniform rate, but the higher an engine speed is, the less time there is to burn the mixture. That's why timing advances with rpm. At 6500rpm, you're having 3,250 combustion events per minute, or 54 per second per cylinder. You have to get combustion started earlier.
i see now thanks for the skinny. so in reality your saying that it would be safer to advance in the higher rpms(wot) vs the lower rpms cause you would need combustion earlier due to the fact that your engine speed is much higher?
I believe that with the 3.0 ECM you can advance the timing significantly in the lower RPM as well due to the fact that the 3.0 ECM is tuned for VE based on the USIM. On a hybrid swap where you lose VCT and you also have it SSIMed, you get a big drop in VE in the lower RPMs. If you look at the 350z timing maps, they have more advance than the 3.0 ECM. But as far as how much advance you can add, you would need to dyno to find out. In the lower rpms (3000-4200) i've advanced the timing between 10-12 degrees and its really only useful for first gear as second gear lands me at 4800 rpm.
How are you at 50* total? I would be cautious if you were running 50* advance under heavy load at any RPM but if you're at high RPM under very light load ( off throttle) then I wouldnt be too concerned but dont quote me on that.
sorry guys for getting kinda off topic but i was intrested in jime's 40* Total
advance.
whlimi, do you notice the timing advances at lower rpm's during partial throttle /light acceleration? Sorry for not understanding the basic concepts of timing. I also wasn't sure if you were even tuning at anything other than WOT
I'm not advocating advancing to 40*. I only brought it up to show an instance where the vq35 didnt knock with 40* advance at WOT. I wish I could find that thread. IIRC Jime has stopped making power past mid 30s. Someone correct me if I have this information wrong.
It all depends on your setup. I do notice a pretty significant difference with more timing advance under light/partial throttle. Below 30% throttle I have my timing ramped starting at 2* advance up to 4* advance before getting more aggressive as it approaches WOT. I'm using MAF voltage, just using TP as an example. I bet I could advance the timing some more under partial throttle because of my setup. Aggressive cams with lots of overlap at lower RPMs will lower your VE in the lower RPMs so you can probably get away with more advance.
Now with the full swap I have gone as high as 32 but 26 seems optimal for it. That is where I run all the time now, 26 from launch to 7k. 22 when spraying.
When I quote timing #'s its WOT only, the rest of the time I let the ECU take care of it. Don't try to outengineer the engineers.
PS The difference in the timing between the 2 setups, results from the lack of variable cam timing in the 3.0 setup.
Damnitttttt. The car was feeling consistently great, responsive. For the first time I felt content with the straight line performance. But as of 2 days ago it feels like how it used to feel with timing problems. Nothing is loose or disconnected...I've still got my Knock Sensor bolted to an extra battery cable which is tapped to the negative terminal of the battery. Any ideas?
The knock sensor kind of rests on a metal surface in the engine bay under the intake tubing, would this cause any ill effect? I'm disappointed now.
Yeah I think that is going to be my next step. My codes are 3.5 swap related...like EGR crap and 02 sensor IIRC. I get a jolting at very low throttle but just replaced my TPS. Maybe my MAF is starting to go bad...again.
By jolting, do you mean like a throttle shock? When you give it a bit of gas it's like someone kicked the back of your seat?? I have that with my auto but it only happens when the TC is locked up. I dont know if there's something wrong or if that's how it is with the VB mod.
not quite. Its like if I'm cruising under 5% throttle it feels like I just dropped the clutch or something. I can see the mixture leans out for that quick second and then it usually continues on its way fine after that. It feels too hard to be a misfire. It only does it at very light throttle and maybe 5 times a day.
Okay I finally got around to doing the resistor mod since the car has felt absolutely BALL-less these past couple weeks. I'm about to take it for a drive so I'll report back with any results. But I'm not expecting anything crazy since I have a MAF code and can tell its on its way out (again :-/)
One weird thing that I cant get off my mind...when I was doing the resistor mod I was stripping the OE electrical tape down to get more length of the KS wires and came across this bare stripped wire wrapped around the two KS wires. I know I've seen something like this before when I was removing tape off another harness somewhere in the car I just can't remember where....it just seemed bizarre. I dont think its a wire that goes to anything but I just left it alone. Anyone know?
All it is is shielding around the wires. Keeps any noise out of the line.
If you ever see this (what I've highlighted in red below) in an FSM wiring diagram, just means that same shielding is around those wires:
Generally only used for 'critical' or emissions components, or anything that the ECU reads a signal from.
ahhh, thank you very much! I hope its not too crucial, I didnt remove it but I dont know how well it was in there when I taped over everything again. And I'm trying to remember if I ever cut that wire when I saw it before....I think it was when I stupidly hacked up that transmission control harness.
The easy way of disconnecting the Knock Sensor
There is also another option in the timing maps for changing when the ECU listens for knock in individual cells. The secondary timing map can also be accessed to change the amount of timing pulled in each cell value so if you want to keep low rpm high load KS protection, then you can adjust the secondary map for pulled timing but keep your midrange and high rpm timing maps at hgih values
For some odd reason when i reinstalled the EU on my 96 when i put in a value for the timing map it would double the advancement. So when i put in 10* it would do 20* advance.
sorry guys for getting kinda off topic but i was intrested in jime's 40* Total advance.
man this car is really pissing me off. I soldered the resistor in there and now have a knock sensor code.......
still have a MAF code as well after replacement. I'm officially pulling my hair out.
also, when yall say "470k-ohm" we are talking about the half-watt resistors, right? Just trying to figure out how the hell I got KS code...I soldered the resistor between the two wires wtf could go wrong.
sorry, the stickies are vague. "If you locate the knock sensor sub-harnass and disconnect it, you can stick a standard 470k leaded resistor into the connector and then tape it into place."
damnit, I knew I was doing something wrong. I dont know that I want to go all the way down to the main-harness just yet. Let me get this straight though. There are two wires coming to the KS harness. I should be soldering one end of the resistor to one of these wires (which one?) and then grounding the other end of the resistor? And then leave the other wire open?
No need to solder anything. Put some electrical over the resistor to ensure it stays in place. If you do it this way you can easily just remove the resistor and plug in the ks if you want
A picture is worth a 1000 words. I just quickly stuck it in there so you get the idea.
Just disconnect the ks and on the other end of the connector that goes to the ecu install the 470k resistor. There are two slots in the connector, signal and ground, bend the resistor wires 90 deg and stick one end in one slot and the other end in the other slot.
