Sponsored by:
Sponsored by: CARiD
Add-to-sticky Request
Old Apr 20, 2009 | 08:35 AM
JClaw's Avatar
Request to add to stickies - this NEEDS to be said once and for all:
All 3.5 swappers should ground their knock sensors directly to the negative pole of their battery if they want uninterrupted, instant full timing all the time.
Jime has been running +10-15 degrees timing advance with a grounded knock sensor for like 2 years now. Just do it already. These swaps are no fun with on/off timing. The 4th gen knock sensor does not like the thinner cylinder walls of the VQ35, and the 3.5 knock sensor does not like the 4th gen ECU so just take out the knock sensor, and bolt it to the negative pole of your battery. FU you touchy sensible piece of sh-
I have had several 3.5 swaps and when the car is untuned it runs rich and tends to have full timing only 50% of the time, sometimes none at all. I mix 91 and 94 octane to be safe. 100% of the swaps I have done have had the intermittent timing power issue. This is why so many of the 3.5 swappers are dissapointed. They go from a preppy 3.0 with full on timing to a pig rich 3.5 with 15 degrees of timing WOT instead of 3.5. Nissan knock sensors suck, and they need to be dealt with.
There, I got it out of my system.
Reset your ECU and drive it around for a few hundred miles. And use 91-94 octane.
I should also mention that you should have at least a wideband to check your AFR before you do this. I would tune rich, 12-12.5:1.
Old Apr 20, 2009 | 08:39 AM
essential1's Avatar
My axles cry for mercy...
Interesting... Note taken...
Old Apr 20, 2009 | 08:43 AM
JClaw's Avatar
After four or five swaps I am officially fed up with the KS. Now with 200 pounds removed the car has a gigantic pair of *****.
Old Apr 20, 2009 | 09:11 AM
ghostmax301's Avatar
so let me get this correct, do we take the knock sensor completely out with the harness still attached and ground it(the knock sensor or the 1 wire going to it) directly to the negative terminal?
Also, does this help with random ks codes or just help in an overall performance upgrade? What i mean is, if im running 13.2 with no KS code, and do this "mod" i would get my lowend-midrange power slightly boosted therefore resulting in lower e.t's/more power?
Old Apr 20, 2009 | 10:03 AM
JClaw's Avatar
You take out your knock sensor with the harness still attached, and instead of sitting on the engine block, the knock sensor sits on the negative pole of the battery
If you are running 13.2 with no KS code (the ECU can pull timing without a code - I had no KS code but it was inconsistant), your timing is fine.
What this does is add consistancy. It will give full timing not 50 or 80 or 90% of the time - it will give you 100% timing all the time. All you have to do is make sure you use good gas - 91 octane or higher. These swaps already run very rich on the stock ECU so you dont have to worry about running lean.
Old Apr 20, 2009 | 10:19 AM
well do you mind if i shot you a PM, for some reason, my car has bee running lean after 5.5k now for some reason, already checked for vaccum leaks, injectors, sparkplugs,codes,fuel pump,fuel filter and AFPR. everything is fine and fuel psi holds to redline. but even at 50+psi, it leans out after 6k and take about 3sec to get from 6k to 6.6k in 3rd and 4th gear
Old Apr 20, 2009 | 10:42 AM
whlimi's Avatar
Or we could just do the resistor mod and get rid of the sensor all together.
Jclaw, what do you mean by inconsistent timing? How much fluctuation are you seeing in terms of degrees of advance? Are you seeing this only in open loop or in closed loop too?
Old Apr 20, 2009 | 10:59 AM
pmohr's Avatar
No more Maximas...
Indeed, why bother even keeping the KS if it isn't going to be mounted where it can read knock? Just throw in the resistor, tuck away the harness, problem solved.
Old Apr 20, 2009 | 11:52 AM
915Max's Avatar
What kind of resistor is being used for this mod!? Sorry guys, i've been outta the loop for a while now.
Old Apr 20, 2009 | 12:58 PM
whlimi's Avatar
IIRC 470kohm.
Old Apr 20, 2009 | 01:14 PM
oTranscendental's Avatar
Yeah same... just had NWP thermo gaskets put in and need to know whats up with the KS..... think I want to do the resistor cuz I'm not even sure that the ks is operational right now.
Old Apr 20, 2009 | 02:31 PM
Product_Of_Korea's Avatar
Good info man thanks for the head up
Old Apr 20, 2009 | 02:38 PM
pmohr's Avatar
No more Maximas...
What kind? Your plain old ceramic resistors, whatever you can find at Radio Shack.
What value? The FSM lists both VQ30/VQ35 KS as 500-620kΩ when good, but the most common value to use is 470kΩ for whatever reason.
Old Apr 20, 2009 | 03:33 PM
95stillenmax's Avatar
is this using the 3.5 sensor or the 3.0 sensor?
Old Apr 20, 2009 | 04:17 PM
whlimi's Avatar
I guess either sensor is going to have issues.
Old Apr 20, 2009 | 07:04 PM
t6378tp's Avatar
Turbo 3.5
Mmmmm, I have a extra ks and harness maybe I leave one in the engine and one on the battery and test it but ways and see what happens
The only thing is my car is tuned to 13.1-13.3 a/f and I would not feel safe DD'ing the car like this but seems to be a great track mod
Old Apr 21, 2009 | 10:57 AM
Weimar Ben's Avatar
Helicopters! Money!!!
I don't understand how grounding the KS directly to the battery will help much. The knock sensor has ~470k of resistance which makes the engine ground resistance of 0.1 completely meaningless compared to a 0.05 ohm of say a 14 ga. ground wire to the battery.
Are you saying that the 3.0 KS should NOT be used with the 3.5 because of the thinner cylinder walls? Maybe I should just do the dam* resistor mod.
My timing does suck, but I've tried two knock sensors, including a brand new one.
If the cylinder walls are thinner and thus causing more noise and vibration which the KS interprets as knock, maybe dampening the KS with a neoprene or nylon washer might help while retaining some of the knock sensing capability.
Old Apr 21, 2009 | 01:13 PM
chillin014's Avatar
jclaw what tuning device do you use to monitor the timing? I dont know if I can tell when/if my timing is inconsistent like you are saying it should be. I need to get something to monitor it ...
Even with consistent 3.0 timing its still not optimal for the 3.5, right?
i need control of my frickin timing already
Old Apr 21, 2009 | 02:39 PM
Weimar Ben's Avatar
Scantools that give you live data will give you the timing advance. The other way you can tell is if the engine feels lively and responsive at small throttle openings, but sluggish at larger throttle openings, esp WOT.
Old Apr 21, 2009 | 03:32 PM
Weimar Ben's Avatar
Maybe I misunderstood you, Jclaw. Did you mean to say mounting the KS directly on the battery or ground it out away from the motor?
Old Apr 21, 2009 | 06:53 PM
chillin014's Avatar
I definitely have experienced what you describe. I've even thought to myself..."this car feels pretty quick until you really step on it" its like...it makes you think its going to do a lot more than it does. Disappointing really...
I'm also curious if the cars jclaw says he experienced this on threw codes or not for the KS. Mine never has.
Old Apr 21, 2009 | 07:03 PM
t6378tp's Avatar
Turbo 3.5
I pretty sure the ks needs direct contact ie metal to metal to operate, this is why the bottom part is bare
or maybe it just has to do with heat
Old Apr 21, 2009 | 08:59 PM
Weimar Ben's Avatar
Sure, it needs metal to metal contact, which is why you'd have to run a ground wire.
Old Apr 21, 2009 | 10:36 PM
TurboS13Hatch's Avatar
Just solder in a 470K 1/2 watt resistor, and get rid of the KS completely. You can get them at Radio Shack for about 25 cents.
Travis
Old Apr 22, 2009 | 07:45 AM
chillin014's Avatar
if I remember correctly, doesnt the KS only have one wire connecting to it? would you be soldering it just on the end of that wire ?/
Old Apr 22, 2009 | 07:46 AM
pmohr's Avatar
No more Maximas...
At the KS itself, there is only one wire, correct. At the harness side, there are two wires. You put the resistor there.
Old Apr 22, 2009 | 07:51 AM
chillin014's Avatar
i got you, thanks. Okay someone go first. lol
actually I have a wb02 w/ gauge hooked up 24/7 so I can see if its running lean....which is usually when knocking starts, yeah?
Old Apr 22, 2009 | 02:09 PM
accordingtou's Avatar
VQ30 DE T
He is on the same path
Good info jclaw Check out what this guy has to say
Last paragraph
http://forums.maxima.org/6995223-post115.html
Im not sure when I will have a EU installed so, we need a EU owner (timing datalog) to step up & test out this theory.
also keep in mind most people (me) dont tq the knock sensor bolt..
Old Apr 22, 2009 | 07:33 PM
whlimi's Avatar
Last paragraph
http://forums.maxima.org/6995096-post2.html
Old Apr 22, 2009 | 08:06 PM
chillin014's Avatar
that was a confusing post. you said it did nothing, and then you said it did as much as advance 13 degrees. I believe you proved jclaws point about consistency..I dont think he was saying it was going to increase timing more than the ECU would allow, just that it would keep it at as high as it would go. Does the car feel considerably better?
Old Apr 22, 2009 | 09:29 PM
Weimar Ben's Avatar
I'm convinced that even 87 octane with the 3.5 motor might be able to use full timing with the 3.0 ECU. I've been using 87 octane during the last tank, with a functional knock sensor, and I'm getting 40-44* of advance at cruising speed on the FWY and low 20's at WOT at high RPMs.
Old Apr 23, 2009 | 04:55 AM
whlimi's Avatar
I never said IT advanced my timing. The EU has advanced my timing. I was just saying that I'm not too concerned with running without a KS even though in some parts of my map I have advanced the ignition timing by as much as 13*.
The difference isnt going to be night and day if you're already running near full timing to begin with. But I'm sure you're going to see a huge difference if your WOT timing is in the 15* and this mod takes it back to mid to high 20s. The biggest thing I noticed was throttle response. Power comes in much smoother.
Old Apr 23, 2009 | 05:05 AM
whlimi's Avatar
I could be wrong but your ECU might be pulling timing at WOT. I logged between 27-31* of advance at high RPMs before adding any advance with the EU.
And is that 40-44* with very light throttle? Say ~ 5% or less?
I only see 40s when I'm below 5% throttle on the Hwy and above that it's low to high 30s.
Old Apr 23, 2009 | 07:11 AM
chillin014's Avatar
ahh, well I'll try it anyway. So there was quite a bit of timing to be added on top of what the ecu runs stock? Did you feel a good power increase (or see any on a dyno) after making your corrections? I need inspiration to get an EU.
Old Apr 23, 2009 | 07:32 AM
whlimi's Avatar
http://forums.maxima.org/all-motor/5...g-advance.html
There's some info in that thread as well as links to threads with really good discussions about ignition advance.
The 13* isnt across the board, just between 3k-4k rpm. For the most part, i've added between 8-10 degrees for the rest of the map at WOT. Unfortunately I do not have a before and after dyno and I've ran it like this for the past 7 months so I dont really remember how it ran before the timing advance. I'm seeing total advance in the mid to high 30s in the higher RPMs.
Old Apr 23, 2009 | 06:23 PM
Weimar Ben's Avatar
Well, my next tank will have premium and the resistor mod and then I'll see what the advance is like.
Yes, the 40-40* of advance is with light throttle, under 10%. It seems that the 3.0 ECU with the 5spd really likes 55-65mph. That's when you get maximum timing advance. I tried at 80mph and timing advance was down to the low 30s. I drove a couple hundred miles once at 60mph and got just under 30mpg.
Old Apr 24, 2009 | 02:52 PM
chillin014's Avatar
thanks. anyone who has "grounded" the KS have any pictures of how they did it?
Old Apr 24, 2009 | 07:15 PM
what about using just a regular metal washer w\ a longer bolt?
to bad i dont have my 3.5 in so i can do comparisons with the data logger
I could if im feeling ambitious i could do a test on the 3.0. I dont know if it would do any good it would do though.
Old Apr 24, 2009 | 07:33 PM
Jime's Avatar
This one of the HUGE benefits of the UTEC. Total control of the KS at all RPM/Load levels.
However I still use my fender well KS while racing, because I don't want my timing pulled no matter what. Using the KS is for tuning not for racing. If you haven't got your timing set properly while tuning, you shouldn't be racing.
Old Apr 24, 2009 | 07:46 PM
whlimi's Avatar
You dont have to ground it to the battery post. Anywhere is fine as long as its off the block and properly grounded. I have a grounding kit so I just ran a ground wire to the ks and secured it with a nut and a bolt.
