Sponsored by:
Sponsored by: CARiD
Cams
Old May 19, 2009 | 09:48 PM
Steve31's Avatar
Cams
3.0 stock cams vs the 3.5 stockers
Is there that much of a gain?
I hear of alot of ppl doing it
Is there a lil lope at idile ?
Guess what I am asking is labor vs the over all HP gain is it worth it in the long run ?
I have a stock 95 SE think of throwing in a set of stock 3.5 cams and maybe boost later.
Would the cams do good under boost ?
Old May 19, 2009 | 10:37 PM
MOHFpro90's Avatar
There are gains to be had. I dont think we have a literal dyno of the differences however.
AFAIK, there will be no lope.
If you are tearing the heads apart already, then its not a bad thing to do. Or if you do the install all yourself, and save most of the money.
Not as familiar with the specs vs boosting.
Old May 19, 2009 | 10:50 PM
95BLKMAX's Avatar
u'll have a gain, but like he said, no one has actually done a before and after dyno for the stock 3.5 cams on a 3.0.
Will you get a lope? no. If these cams made a loppy idle, all 3.5s would lope. I had S1 knock off cams and it BARELY lopped once warmed up on a 900rpm idle.
Cost benefit? well, dont expect 30whp out of them lol. I wouldnt bother going through all that work for stock 3.5 cams though. To me the S1 cams are a damn good upgrade from the stock 3.0 cams to make it worthwhile.
Even the S1 cams are mild enough to work fine with boost. Stock 3.5 cams are fine as well. Ultimately you'd want a cam with no overlap for a full FI setup, but realistically that wont happen due to cost effectiveness lol
Old May 20, 2009 | 04:09 PM
Steve31's Avatar
yeah just found out the diff between the cams
stock 3.5 has 10mm lift and the 3.0 has 9mm I dont think 1mm would make much diffrence
Where can I find a set of those knock off's?
Old May 20, 2009 | 08:54 PM
maxboy325's Avatar
^^^^ When you find them let me know
spazma7ik
Jan 12, 2017 09:38 PM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
conansriver
Sep 11, 2015 10:26 AM
