Sponsored by:
Sponsored by: CARiD
VQ35 VAFC settings?
Old Aug 2, 2009 | 12:23 PM
viperboy's Avatar
VQ35 VAFC settings?
I was just wondering if anyone had any tuning settings for their VAFCs on their 3.5s. Mine was professionally tuned, so I don't need to change anything. Just wanted to see what others had. I will post up my settings shortly. I just wanted to see what other people had that were running an I/H/E setup.
Old Aug 2, 2009 | 01:19 PM
viperboy's Avatar
Here are my settings. I don't know what the tuner did to factor -2% after 4k RPM. I can't find the settings for that anywhere.
Wide Thr - LVt 10 RPM +0 [next button] HVt 40 RPM +0
Narr. Thr - LVt 10 RPM +0 [next button] HVt 40 RPM +0
V/T Cont - L -> H: 5800RPM
- H <- L: 5400RPM
V/T Unmt - Hi<<L: +0%
- Lo<<H: +0%
TH - Point - Lo 10% Hi 50%
Ne-P: HVt - Ne1 - 4000
- Ne2 - 4500
- Ne3 - 5000
- Ne4 - 5500
- Ne5 - 6000
- Ne6 - 7000
- Ne7 - 8000
- Ne8 - 9000
Ne-P: LVt - Ne1 - 1000
- Ne2 - 2000
- Ne3 - 3000
- Ne4 - 4000
- Ne5 - 5000
- Ne6 - 5500
- Ne7 - 6000
- Ne8 - 6500
So to me, it doesn't look like any correction is taking place. But, when in Monitor mode, I have it set to watch correction and sure enough, after 4k, it starts dropping from -0.1 to -2.0 near 6500. Any more insite on this would be good. Also does this look like it should? Anything that should be changed? Thanks
Old Aug 2, 2009 | 03:48 PM
t6378tp's Avatar
Turbo 3.5
part throttle starting at 30%-70%
tuned to 12.8-13a/f
idle-2800rpms 0
3100 -2
3300 -2
3600 -3
3700 -3
3800 -4
3900 -4
4000 -4
4100 -4
4200 -6
4300 -6
4400 -5
4500 -7
4600 -7
4700 -7
4800 -6
5000 -4
5200 -4
5400 -4
5600 -3
5800 -3
5900 -3
6000 -3
6300-redline -3
wot
tuned to 13-13.2a/f
idle-2800rpms -3
3100 -5
3300 -5
3600 -6
3700 -6
3800 -6
3900 -6
4000 -8
4100 -8
4200 -8
4300 -8
4400 -9
4500 -8
4600 -8
4700 -7
4800 -8
5000 -5
5200 -6
5400 -7
5600 -5
5800 -4
5900 -7
6000 -7
6300-redline -7
I also had the low to high crossover set at 4500rpms
Old Aug 2, 2009 | 03:51 PM
t6378tp's Avatar
Turbo 3.5
your looks wrong a vafcs has 24 tuning point and you don't
12 before the crossover point and 12 after and if your crossover rpm it 4500 then your low tune should not go above that and your high should not go below that
btw these corrections were for a 4.5 gen with shorty header, y-pipe, exhuast, ssim and a pftb with the fuel psi set at 35 idle and 43wot
Old Aug 2, 2009 | 04:07 PM
viperboy's Avatar
You probably have a VAFCII. I just have a VAFC. I was just wondering if there were slight adjustments I could make to make it run better.
What I would really like to know if how to tune it myself and how to remove or add air/fuel.
Old Aug 2, 2009 | 05:31 PM
t6378tp's Avatar
Turbo 3.5
yes I had the vafc2 only thing that really changed is the amount of tuning point the crossover thing still applys
it's really easy to tune go on the apexi website and read the instructions
Old Aug 5, 2009 | 02:24 PM
EnervinE's Avatar
i has college
Just in case you weren't aware, you can't do any further tuning without a wideband o2 and datalogging, or more dyno time. Altering your A/F ratio without knowing what it is is dangerous.
Old Aug 6, 2009 | 10:21 AM
viperboy's Avatar
Yes, I am aware of that. I just wanted to see what other settings people had so I could try them out next time I tune with a wideband.
Old Aug 6, 2009 | 01:05 PM
DAVE Sz's Avatar
Hooooooonda.....
^ that's a pretty stupid idea as well.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
mclasser
22
Nov 12, 2020 01:58 PM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
