Sponsored by:
Sponsored by: CARiD
00vi not opening
Old Aug 6, 2009 | 11:27 AM
Mr.Duck's Avatar
00vi not opening
so at maxus i dynoed my car, and the dyno read like i had my stock intake manifold off, the power just dropped past 5500rpms or so.... so when i checked my VI, alas it was not opening
so i searched and searched, and i even checked my VIAS and it is still in tact, but my VI is not opening.
my switch is working, i opened it up, and the light comes on when i hit the RPM rangeits supposed to open at, but my VI is still not opening. Could it be the solenoid? anybody have a part number for the solenoid?
anybody have any ideas on what the problem could be?
Old Aug 6, 2009 | 12:36 PM
ajcool2's Avatar
What kind of switch are you using?
Old Aug 6, 2009 | 12:44 PM
Mr.Duck's Avatar
IIRC, its a summit racing switch
Old Aug 6, 2009 | 01:03 PM
DAVE Sz's Avatar
Hooooooonda.....
did you look at the lil cup closely? Mine looked good from the outside and moved when I used the outer shaft to spin but when I opened it up, the hole in the cup was worn out and the rod just spun inside the hole. Run vacuum to one of the nipples, not sure which, to see if it opens to eliminate possibilities...
Old Aug 6, 2009 | 01:50 PM
Mr.Duck's Avatar
when i opened it up,the cup moved fine when i manually opened the switch from the outside, is there still a need to run a vacuum to it?
Old Aug 6, 2009 | 02:35 PM
96nismoSE's Avatar
try the VIAS test by putting a vacuum hose on the nipple and sucking in air to if its holding vacuum at all.
Old Aug 6, 2009 | 06:59 PM
MOHFpro90's Avatar
Just because that LED is lighting up, its possible that there is no voltage going to the valve. Might wanna multi meter test.
Old Aug 8, 2009 | 08:41 AM
DAVE Sz's Avatar
Hooooooonda.....
dave, did you figure it out?
Old Apr 3, 2010 | 12:27 PM
Mr.Duck's Avatar
soooo i finally got around to fixing my 00vi a couple weeks ago... it was really stupid of me...
the battery terminal had some corrosion on it, i didnt really think much of it, but when i took it off to clean it, i saw the power wire i had shoved in there for my 00vi was corroded through... so no power was getting to the vi.... well its all fixed and dandy now lol
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
lrb6805
Sep 30, 2015 08:12 AM
lkiller123
Sep 21, 2015 03:00 AM
