Sponsored by:
Sponsored by: CARiD
Rev up oil Pump installation?
Old Sep 11, 2009 | 09:53 AM
OC_Nooby's Avatar
Since I have a dead spare motor lying around I decided to take it apart and see exactly how the oil pump fits in. I got to the point where the chain cover was 2 bolts away from being taken out. I believe the other bolts are from underneath the oil pan.
My question is, once the chain cover is taken out you have this gear on (correct me if i'm wrong) the crankshaft that has to be taken out before the oil pump can be installed. Now this gear, does it require a special tool to come out or can it be taken out with a flat head screw driver and some love taps?
Thanks to anyone who can help out!
Old Sep 11, 2009 | 10:09 AM
mmg23max's Avatar
No special tool required, yea you can lube it WD if anything and just tap it of the cranshaft.
Old Sep 11, 2009 | 04:17 PM
pmohr's Avatar
No more Maximas...
No real need to even tap it off, they tend to just slide right off (at least on every VQ I've torn apart).
Yes, there are two bolts that go up through the upper oil pan into the front cover, and you'll also have to work out the two alignment dowels.
Old Sep 13, 2009 | 08:43 PM
OC_Nooby's Avatar
Thanks for the help!
Rev up oil pump installed
Old Sep 13, 2009 | 09:08 PM
MDeezy's Avatar
You installed a rev up oil pump on a ...... 3.0? 3.5?
Old Sep 13, 2009 | 09:29 PM
OC_Nooby's Avatar
3.5 rev up oil pump on a 3.0
Old Sep 13, 2009 | 09:43 PM
MDeezy's Avatar
interesting...what are your plans?
Cotozic
Jun 28, 2017 08:01 PM
iflexsteel
Sep 15, 2015 03:37 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
