Sponsored by:
Sponsored by: CARiD
My VAFC2 + LC-1 wideband Tuning
Old Oct 11, 2009 | 07:21 PM
shadyonedeath's Avatar
Current tuning Setup:
-Innovate LC-1 (wideband)
-VAFC2
Current Performance:
-00vi w/DEK injectors
-Warpspeed y pipe w/wideband bung
-Automatic transmission
Runs are in 2nd gear, starting as close to 3000k and ending in 5100rpms.
Notice the lean spikes in the 3k-4k area. Looks like i took out a bit too much fuel there. (I know RPM isn't shown but the log ranges from 3k-5100rpm, so just estimate) I think i need to move some fuel points in the VAFC2 to the low end and spread out the top. Mid range seems to be more sensitive to the larger injectors and not interpolating between points well enough.
BTW, im not done. I had to get out of there after 8 runs with a snapped b pipe to avoid attention. good tuning practice though.
Old Oct 11, 2009 | 09:01 PM
ajcool2's Avatar
How much fuel are you removing with the VAFC-II? My AFR is sitting right at 12 all the way across right now.
Old Oct 11, 2009 | 09:15 PM
ill get that for you in a bit, i need to go outside and write it down.
3100 - (-7)
3300 - (-8)
3500 - (-9)
3700 - (-9)
3900 - (-10)
4100 - (-10)
4300 - (-11)
4500 - (-11)
4700 - (-11)
4900 - (-11)
5000 - (-11)
5100 - (-11)
I think those two lean spikes in the beginning are the -9's.
Old Oct 11, 2009 | 09:41 PM
ajcool2's Avatar
Cool I think the most I've taken away is -5. That was all guessing though. Ive been looking around for a thread like this to give me an idea how much fuel I need to remove but couldnt find one. Good info and keep us updated. Are you planning on dynoing anytime soon?
Old Oct 11, 2009 | 10:26 PM
You're on a 3.5 and 290cc injectors, correct? Would the 3.5 affect AFR compared to my 3.0?
TBH, I dont know if it would be safe to use my fuel corrections. Im assuming you dont have a wideband, did you get your AF from a dyno? Was their wideband stuck in your muffler? (which would give you a leaner read out)
Ill update Thursday when my catback gets put in. I decided to just go ahead with a crimp setup since NA doesn't really gain much from the b pipe. Once thats done, ill tune 3k-6500rpm.
Old Oct 12, 2009 | 08:22 AM
ajcool2's Avatar
My car is setup like yours 00vi auto. My girls car is the 3.5. Yeah I got my AFR from a dyno. I really do need to get a wideband tune my car.
Old Oct 12, 2009 | 08:58 AM
Get the Lc-1 from abadcamaro or something on ebay. Good authorized dealer.
Mine was like ~160$ with the o2 sensor, computer cable, and the LC-1.
Old Oct 12, 2009 | 01:54 PM
maxboy325's Avatar
That's subjective.
AJ has a super flat A/F line, it acutally kind of wierd.
Old Oct 13, 2009 | 08:39 PM
Would it be possible to EASILY wire up my Transmission control to let me hold a certain gear? I've remember people making manu-matic boxes that are controlled by the cruis control buttons but that was long ago.
I want to be able to hold 2nd or 3rd without it down shifting at WOT to tune below 3k @ WOT.
Old Oct 16, 2009 | 10:08 AM
Slight confusion. I managed to get a smooth 13.5-13.8 AFR in 2nd gear but when I tested it in 3rd, my AFR dropped to 12's.
Do I really want the most power in 3rd? Or should I stick with 13's in 2nd?
Old Oct 16, 2009 | 04:02 PM
DAVE Sz's Avatar
Hooooooonda.....
you're supposed to tune in 3rd. 1st and 2nd are too short to get the data properly.
Having said that, not sure why it would matter which gear you tuned in, it's not a dyno.
Old Oct 16, 2009 | 04:22 PM
Well, im wondering because if I tune in 2nd for 13.8 AFR, does that mean 1st gear is in 14.8's AFR and 4rd is in 12.8 AFR?
Im just comparing data. Like i said, after completing street tuning in 2nd, i got a nice flat 13.4-13.8 AFR line, but when i logged the data in a 3rd gear pull, it came out in the 12's.
Old Oct 16, 2009 | 08:37 PM
MoncefA33's Avatar
That means I'll be going 100mph before my datalog is over...
Good luck on your tuning man it's fun stuff
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
Maxboy23
Sep 4, 2015 06:04 PM
