Sponsored by:
Sponsored by: CARiD
Help: UTEC
Old Nov 19, 2009 | 08:20 PM
Gemner's Avatar
Help: UTEC
I am currently trying to work out a breaking up problem and a super rich off-throttle situation.
When I go full throttle in the turboxs map, the car will accelerate from low RPM to about 3000RPM, but after that its like a soft limiter or a 2-step kicks in, its really weird. I have the #1 pin on the connector grounded so I dont think thats problem. Also the car accelerates fine in the ("0") stock map or any unchanged map. Any thoughts? Im going to make sure my parameters are 100% right before I get into more serious diagnosing.
Another thing is a really strange problem. It happens in every map. When I let off the gas and let the engine brake, as soon as the revs drop to approx. 1750RPM or lower I start getting a lot of popping and backfires out the exhaust. It smells like the car is going VERY rich and that is the cause of the backfiring, but I dont really understand why the UTEC would cause me to go super lean. I have taken the UTEC out and confirmed it doesnt do this with only the stock harness and ECU. Any thoughts on this part either?
Old Nov 20, 2009 | 04:30 PM
Gemner's Avatar
So, it looks like the cutting out start at 2000 rpm, which is exactly where the UTEC takes control of the timing. could this be a problem with the ckps wire or what? Remember it runs fine, accelerates fine in the "0" map
Old Nov 20, 2009 | 05:41 PM
Gemner's Avatar
I also just found that in the dashboard the UTEC displays the current timing (while running) to be 0 degrees so im guessing that its not reading the timing right? Do i need to connect both the ckps (pos) and ckps (ref)? I only see one pin for the ckps in the pinout (pin 95 for 5.5gen), is there another? Or do I need to connect the cam position sensors to the UTEC?
Old Dec 14, 2009 | 08:30 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
I'm 90% sure the cam position sensor was connected for my install.
Cotozic
Jun 28, 2017 08:01 PM
MaxInfamy
Forced Induction
Aug 24, 2015 12:01 PM
fred reid
26
Apr 25, 2009 06:44 PM
tvn_1010
Dec 30, 2005 09:49 AM
tvn_1010
Aug 19, 2004 12:27 PM
