Sponsored by:
Sponsored by: CARiD
problems after 5 speed swap
Old Jan 8, 2010 | 04:19 PM
mywhitewolf's Avatar
i've got a 96 A32 with an 00vi and turbo, I've just completed a 5 speed swap and i'm having problems with the idle, when rolling to a stop with the clutch in the car idles at 2k rpm for a couple of seconds, before dropping to a idle of ~700 odd. I've tried winding out the idle screw but that just makes the car stall out when it drops back to the 700~ rpm idle.
Would changing to the 5 speed ECU fix this or is this a unrelated problem? its also possible that this was happening when i was an AUTO as often my RPM at idle would sit at 1000.
Any ideas of what else could cause the problems?
Old Jan 8, 2010 | 06:00 PM
i30dvr's Avatar
its your IACV....if you unplug it it will work fine. My car did the same thing after the 5spd swap and i did the same thing w/ the screw of the TB but that only helped after the rpm dropping after bout 5-8sec.....changing the ecu to a 5spd will eliminate the problem and you can have your IACV connected.
Old Jan 8, 2010 | 07:46 PM
thanks, i'll give that a go
Old Jan 8, 2010 | 07:51 PM
pmohr's Avatar
No more Maximas...
Indeed, the problem lies with the 4AT ECU. Swap that out, problem solved.
Old Jan 10, 2010 | 10:51 PM
thanks guys, this fixed it. much nicer car to drive now.
Maybe someone should add this information to the 5 speed swap howto?
matts95max
Apr 23, 2025 10:44 AM
jfl330
Sep 4, 2015 01:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
iflexsteel
Sep 2, 2015 08:04 AM
