Sponsored by:
Sponsored by: CARiD
Bbmaf & greddy eu settings
Old Mar 8, 2010 | 04:05 AM
TDotMax's Avatar
Anyone know what settings i should use once i install the bbmaf? Thanks
Old Mar 11, 2010 | 09:25 AM
TDotMax's Avatar
Anyone? Someone must be running a BBMAF and Greddy EU
Old Mar 11, 2010 | 09:40 AM
Kevlo911's Avatar
Kevlo for President
I was under the impression you keep the vq35(or 30) settings since it is the vq35 (or 30 if dek) element. Then you tune the air flow map/injector map
Old Mar 11, 2010 | 01:42 PM
*Jay*'s Avatar
Im gonna find out in about a week or so when I install my EM-U but I do believe it will be done with the "Airflow change to" pg.12 setting under the "Vehicle" tab in "Parameter setting". Its gonna take some figuring out since I dont have it installed just yet but I plan on getting it to run/idle with a stock diameter maf and then play with it until I get the change corrected to correct my idle with the BBMAF.
Only thing that worries me is that Mafs for the VQ35 arent cheap so I am gonna call Greddy tech support and ask them to be sure before I fry anything.
Old Mar 11, 2010 | 01:48 PM
MoncefA33's Avatar
You can use the airflow adjustment map or bolt it up and do some datalogging and just make normal changes to your I/J map.
Old Mar 12, 2010 | 11:14 AM
TDotMax's Avatar
Thanks guys. Do you think car will be driveable with it slapped in there? Reason being is I don't want to show up at the dyno place and start installing things there.
Old Mar 13, 2010 | 09:46 PM
MoncefA33's Avatar
It shouldn't. Boosted 4th gens running EU/Z32 MAF combinations haven't had issues. Closed loop shouldn't be a problem but keep a close eye on AFR during WOT runs due to the bigger housing could cause you to go lean.
Old Mar 14, 2010 | 12:08 AM
streetzlegend's Avatar
I got EU and Z32 maf, I dont have issues (dont kno why you would have), just turn the normal settings as if you had a stock maf, just gotta make corrections for the bigger maf thats all, no biggie. I run my ECU open loop all the time, I dont have any o2's hooked up, however I still have 14.7 a/f while normal driving and cruising (manually tuned).
Old Mar 14, 2010 | 05:27 PM
stillpimpin's Avatar
quick question street how are you running open loop all the time, just asking cause I want to get rid of my O2 as well.. srry bout jacking ur post...
Old Mar 14, 2010 | 06:39 PM
MoncefA33's Avatar
Depends on the software you're using. You need to find a way to feed the factory ECU a high TPS signal first to make it think that it's in open loop and then tune accordingly.
Old Mar 17, 2010 | 04:15 AM
TDotMax's Avatar
Benefits?
Old Mar 17, 2010 | 10:48 AM
MoncefA33's Avatar
Benefits?
For running without an O2 sensor? IMO it's worthless for an N/A car, but for streetz's car (Built VQ35/big turbo...) it would be easier to drive the car and tune it when cruising if you have full control of injector pulse at any given time. Maybe he'll chime in and correct me if I'm wrong.
Old Apr 4, 2010 | 05:07 AM
*Jay*'s Avatar
So how did this turn out for you, get your BBMAF up and running???
Old Apr 5, 2010 | 03:01 AM
TDotMax's Avatar
Soon, waiting on a PF tb adaptor plate before installing everything. Then to book dyno time
Old Apr 5, 2010 | 01:04 PM
*Jay*'s Avatar
I hooked up my EMU yesterday briefly before I had to pull it, need to double check my wiring since it wasnt seeing the TPS.
But let me know if this sounds right, by using a negative value (-12% for instance) on the "AirFlow Adjustment" map I would be compensating for the increase in maf housing size.
I tried to find a suitable value in the "Airflow change to" but by the looks of it the VQ is the biggest engine listed so I dont think any of the other engines listed will have a larger maf housing. Wont know for sure until I get it hooked up properly.
Old Apr 5, 2010 | 01:44 PM
NmexMAX's Avatar
dot dot dot ...
The Q45 wouldn't happen to be there?
Old Apr 9, 2010 | 01:13 PM
Donchoka's Avatar
did you get this to work i was wondering if you have a 5.5 gen or 4th gen? i have my eu hooked up and everything seems to be wired right but when i put in the vq35 in the drop box i get a no maf signal should i be using the vq30det?
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
