Sponsored by:
Sponsored by: CARiD
3.5 Swap Auto, Smooth Idle, no IACV
Old Apr 23, 2010 | 11:34 PM
streetzlegend's Avatar
ok so ever since I have had the 00VI to now the 3.5, I have never had the IACV. But right now I am just getting tired of the rough shaky idle while in gear and at a stop, it drives me nuts, specially when its hot out, im upset, then feel the car shake, just fks up my day lol.
Now! how are you guys with 3.5's idle'ing? smooth?
My A/F is on point, vacuum is fine as well (-15 in gear), which means it has to be the timing that needs adjustment, what timing are you guys showing at idle while you are in gear.
My setups is:
- 3.5 TB with drilled plate (to not have to adjust the idle screw so much and throw off the TPS),
- TPS at aprox 0.60v (fsm says .15-.85v at idle is within spec)
- Fuel pressure at mid/high 20s psi with 600CC DW
What do you guys suggest so that I can get my idle as smooth as stock? mess with timing?
Old Apr 24, 2010 | 01:06 AM
diymaximakid's Avatar
My setups is:
is it popping?studdering? free revs easily?
Old Apr 24, 2010 | 08:00 AM
essential1's Avatar
My axles cry for mercy...
One thing you have to remember streetz is that most people who have done the 3.5 swap are running manual transmissions. We're always in neutral when sitting there idling so we wont feel the car shake. So us stick shift guys might be experiencing similar idle problems as you but it's not being felt in the cabin. lol
Do you feel it in neutral too?
Old Apr 24, 2010 | 08:08 AM
Kevlo911's Avatar
Kevlo for President
Add the IACV
Old Apr 24, 2010 | 10:16 AM
Well it dosnt missfire or anything, it revs quick and free, the car rides perfect. But once you come to a stop and you have it in gear, specially with A/C on, its just rough.
Yeah it makes sense about the 5sp, the other 3.5 swaps that I have dealt with didnt have noticeable rough idle due to the reason you mentioned, essential.
I am just worried about the IACV because I have heard of a few people put it on and still have issues with it.
Old Apr 24, 2010 | 05:05 PM
I just fukd up the car, biggest mistake iv ever made was to hook up the injector harness on the EU. Now car dosnt even attempt to start, ****ing great!!!
Old Apr 28, 2010 | 09:08 AM
whlimi's Avatar
I have a pretty rough idle too. Most likely due to the cams and poly mounts but I also noticed that my ignition timing is around 8* at idle. I've tried everything to get it to 15* but no luck. I'm running an IACV and it doesnt help. FP is at 34 psi with vacuum(13) and 42psi at WOT on stock 350z injectors.
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Maxboy23
Sep 4, 2015 06:04 PM
