Sponsored by:
Sponsored by: CARiD
Fidanza Flywheel
Old Apr 29, 2010 | 02:47 PM
shift_123456R's Avatar
Fidanza Flywheel
I bought a used flywheel from my friend and he had it in a 4th gen with a 6spd swap. He modified the 3.5 ring on the back of the flywheel (engine side) to use on 3.0 timing.
Now my question is, the timing ring from the OEM flywheel is it removable? Can i take it off the OEM flywheel and assemble it to the fidanza? Or do i have to call fidanza and order the replacement part for the flywheel?
All inputs are appreciated.
Old Apr 30, 2010 | 02:13 AM
anybody?
Old Apr 30, 2010 | 02:40 AM
Gemner's Avatar
Is the ring on the fidanza removable? I know the ring on the stock flywheel isnt necessarily "removable", but im sure it can be removed and fixed to the fidanza, its riveted to the stock flywheel though
Old Apr 30, 2010 | 05:14 PM
Remminator's Avatar
I took the timing ring off my original flywheel and installed it on the fidanza. It fit fine, better than the flywheel fit on the crankshaft for sure.
Old May 2, 2010 | 04:47 PM
Gemner's Avatar
you have a 3.0L timing ring though dont you?
Old May 3, 2010 | 09:50 AM
Remminator's Avatar
I think if you are using the 3.0 timing, you will need the timing ring off the original oem flywheel. I am using 5sp tranny with 3.5 block, 3.0 timing. When I got my fidanza flywheel, it had no slip ring.
Old May 3, 2010 | 07:08 PM
Gemner's Avatar
i would assume since hes a 5.5gen that he would want to remove the ring from the 3.5 flywheel and put it on the fidanza
Matt93SE
May 24, 2019 02:58 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
