Sponsored by:
Sponsored by: CARiD
Dek swap problems
Old Jun 27, 2010 | 11:35 PM
VQphantom's Avatar
Dek swap problems
I did a dek swap(Lightly moded) and im having an overheating problem i put the de coolant tempsensor on the dek and the little black sensor in front of (i think they are suppoes to be switched not sure) But my engine is overheatings under Light /heavy load even sometimes when im driving normal for a long distance . Coolant bubbles and under my hood looks as if it was pouring out of my resorvoir I ReALLY NEED SOME HELP BECAUSE IM ABOUT TO GIVE UP ON THE MAX GAME........... I have a dek swapped 4thgen, greddysp2,testpipe,pop charger,y-pipe with 3inch flex,and jwt ecu PLease help!!!
Old Jun 28, 2010 | 10:00 AM
MoncefA33's Avatar
It could be your thermostat that's not opening up.
Old Jun 28, 2010 | 10:44 AM
VQphantom's Avatar
When i first put the motor in and starting doing sme tuning I noticed it was overheating so i put the de tstat on the dek and it was doing the same . I think might geta brand new tstat
Old Jun 29, 2010 | 08:12 AM
InfiniwhiptinitiII's Avatar
man, that sucks... what about that gasket?
Old Jun 29, 2010 | 08:13 AM
my gasket
Old Jul 1, 2010 | 10:08 PM
93altima's Avatar
Turbo 4th Gen
it could be the tstat and i believe the dek has 2
Old Jul 2, 2010 | 02:42 AM
Product_Of_Korea's Avatar
That is correct depending on what coolant log he has.
Codes?? Which T-stat did you replace? Timing chain side? or By the temp sensor?
Old Jul 9, 2010 | 01:12 PM
MAXbendikssen's Avatar
Let us know your findings, I'm about to do that same swap.
Old Jul 9, 2010 | 01:41 PM
ajcool2's Avatar
He switched the one from his old motor to the DEK and still has the same problem. He thinks the head gasket is blown.
Old Jul 9, 2010 | 05:14 PM
Mad-MAX_SE's Avatar
Still kickin'
I'm not terribly familiar with the DEK coolant tube (if that is where the second t-stat is), but according to his first post, he just transferred the sensors to the DEK coolant tube. So if there is one in the coolant tube, that would be my guess. Would also explain the bubbles in the coolant since it's a restriction prior to the water pump.
matts95max
Apr 23, 2025 10:44 AM
Mar 12, 2020 12:06 AM
MaxRPM6
Sep 11, 2015 06:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
slowlifer
Sep 8, 2015 05:53 AM
