Sponsored by:
Sponsored by: CARiD
shooting for 285whp-300whp n/a
Old Sep 10, 2010 | 06:21 AM
datdude20's Avatar
I'm just kinda curious to see what some yal think. I'm trying to squeeze as much power out of this motor as I can without building the motor.
My current set-up:
Custom SRI
ObxV2 headers
3" test pipe
Cattman 3" exhaust
Jwt flywheel
SSIM
Nwp spacers
Lightweight pulley
Ported upper & lower I'm
BC stage 2 cams
TS F-spc ecu(7200 rev limit and Z33 cam timing)
NWP torque damper
POLY mounts
S-AFC
Lemme know what yal think...I just wanna see what people got to say. I'm about 90% sure I will be close to 300whp. I plan on gettin a meth kit and V-manage soon.
PS: this is another one of my "I'm bored" threads
Old Sep 10, 2010 | 06:52 AM
datdude20's Avatar
:metalmax:
Old Sep 10, 2010 | 07:45 AM
MoncefA33's Avatar
With an LR MAF you should be able to seal the deal. V-Manage too for sure.
Old Sep 10, 2010 | 08:22 AM
datdude20's Avatar
Until I see a dyno showing the gains from a LR maf I aint messing with it
Old Sep 10, 2010 | 08:24 AM
phatboislim's Avatar
i dont know if it was for a vq30 or vq35...but the thread i remember seeing for the LR MAF was pretty significant..with what you have, i agree with Moncef
Old Sep 10, 2010 | 08:58 AM
tookrzy4u192's Avatar
i read that QMax from nycnissans.com hit 300 na.. i could be wrong though
so it's possible, goodluck!
but you'll need a exhaust cutout to get the car there..
Old Sep 10, 2010 | 09:00 AM
MoncefA33's Avatar
With your nonbelievin azz...
http://forums.maxima.org/all-motor/4...iscussion.html
Always listen to Moncef.
Old Sep 10, 2010 | 09:04 AM
datdude20's Avatar
Yea I know but those were his uncorrected numbers
Old Sep 10, 2010 | 09:17 AM
Unklejoe's Avatar
Ditch the SAFC and get an Emanage Ultimate or UTEC so you advance some timing and get some real power out of the tune.
Old Sep 10, 2010 | 09:55 AM
datdude20's Avatar
Haven't seen anything impressive with either of those
Old Sep 10, 2010 | 09:56 AM
accordingtou's Avatar
VQ30 DE T
1. UTEC with agressive timing & extended limiter
2. Meth(for pump gas runs)
4. Arp rod bolts...
3. Purchase a/c, pwr steering delete belt (Dyno/ track only)
4. Light, small diameter front wheels. (dyno/ track only)
5. 3" cutout
Old Sep 10, 2010 | 10:06 AM
datdude20's Avatar
I'm about to start a "WTB: land rover maf thread
Old Sep 10, 2010 | 10:08 AM
MoncefA33's Avatar
That's WTF I thought
Old Sep 10, 2010 | 10:09 AM
datdude20's Avatar
4. Arp rod bolts...
5. 3" cutout
1.I have extended revs
2. Meth will be here soon
3.PS is already gone..lol
4.I've been reving to 7200 with out rod bolts and I've been fine. I don't plan on revving higher yet
5. I have lightweight wheels already
Old Sep 10, 2010 | 10:10 AM
datdude20's Avatar
Old Sep 10, 2010 | 10:11 AM
MoncefA33's Avatar
Old Sep 10, 2010 | 10:17 AM
LOL
Old Sep 10, 2010 | 10:23 AM
i started a thread a while back with no luck from the org.. its just better to get it from car-parts.com i guess
Old Sep 10, 2010 | 10:38 AM
bamboomerang's Avatar
MAP/speed density tune, ITB's, longtubes, portmatching, higher rev increase (valvesprings, oil pump, rodbolts) - that oughtta do it if you can $$$.
Old Sep 10, 2010 | 10:59 AM
datdude20's Avatar
Old Sep 10, 2010 | 11:01 AM
datdude20's Avatar
I don't think I need ITB's...lmao
I wasn't asking what I need...I was asking if anybody had any idea as to what I would make with my current set up
Old Sep 10, 2010 | 11:02 AM
Stillen Maxima's Avatar
Pay to Play
Do I hear a 5th 5.5 comming? Or do I save my spare for you ?
Old Sep 10, 2010 | 11:12 AM
ajcool2's Avatar
Get a really good tune and your set.
Old Sep 10, 2010 | 11:24 AM
datdude20's Avatar
Got my motor yesterday O6 3.5 with 50k on it
Old Sep 10, 2010 | 11:34 AM
datdude20's Avatar
Old Sep 10, 2010 | 11:38 AM
maxboy325's Avatar
My current set-up:
Custom SRI
ObxV2 headers
3" test pipe
Cattman 3" exhaust
Jwt flywheel
SSIM
Nwp spacers
Lightweight pulley
BC stage 2 cams
NWP torque damper
POLY mounts
S-AFC
LLS red = cellphone grammar correction
Old Sep 10, 2010 | 11:43 AM
Deckdout2's Avatar
Play with my balls
If you hit 300whp with your mod list, I surely hope I can surpass that goal easily with my list. That V-manage and LRMAF should give you a nice boost in itself!
Old Sep 10, 2010 | 12:06 PM
datdude20's Avatar
I'm looking for one now
Old Sep 10, 2010 | 12:08 PM
datdude20's Avatar
LMAO!!!! That **** pissed me off
Old Sep 10, 2010 | 12:09 PM
datdude20's Avatar
The highest I've seen with a similar set-up(different ecu's) is 291
Old Sep 10, 2010 | 12:21 PM
t6378tp's Avatar
Turbo 3.5
I think you will be closer to the 290 range but with the cutout, a/c delete, more timing along with the meth you should reach your goal
But I have a question what is the vmanage going to do over your TS F-spc ecu with Z33 cam timing, cause when I got my g35 tuned all playing with the cams timing did was shift the power band and extend hp/tq curve but it did affect peak hp
Old Sep 10, 2010 | 12:24 PM
MoncefA33's Avatar
wat
Old Sep 10, 2010 | 03:00 PM
VQ30 DE T
The only difference i see between your setups is high compression pistons.
Old Sep 10, 2010 | 03:23 PM
Deckdout2's Avatar
Play with my balls
Well that, ported heads, 5 angle serdi valve job, gen 3 cattman headers, shorter final drive, and a few other things to boot......
Old Sep 10, 2010 | 03:58 PM
datdude20's Avatar
Old Sep 10, 2010 | 04:07 PM
datdude20's Avatar
gen 3 cattman headers, ......
Old Sep 10, 2010 | 04:46 PM
VQ30 DE T
vq35 heads flow great out of the factory. A NJ HEAD job and "gen 3" headers are not going to make a huge difference if you both are reving to 7200... 8k rpms is a different story
Old Sep 10, 2010 | 08:24 PM
datdude20's Avatar
......No
Old Sep 10, 2010 | 08:42 PM
Oh. My guess is about 265ish peak, depending on the dyno. Why is ITB's so hilarious? One of the few recorded FWD 3.5's to break 300 is equipped with em. Who else has done it? The Z guy's had to go inside, but they've got a little more drivetrain loss.
Old Sep 10, 2010 | 09:01 PM
MoncefA33's Avatar
Z33 cam timing is most optimal for Z33 cams (which on the DE-Z are the same as on the 5.5 Maxima) and SSIM (since the intake manifold is similar to the Z33IM)
However when you switch to those BC 264s that cam timing is no longer optimal. I've read on my350Z about how one member played with cam timing on a DE-Z and Tomei 264s and his AFR went from 12.x to 14.x at WOT. That's a huge increase in airflow. It shifts powerband more than it adds power, (which is why anyone using Stephen Max adapters on a 3.5 swap/cammed DEK pays attention to the timing), but the fact that it improves breathing shows it will help peak numbers.
What's the setup on your G35, by the way?
Because of this.
291whp on stock MAF, stock heads, and ONE throttle body. And that Jenvey ITB setup is bloody expensive. And I bet you can play with the v-Manage to make your car run harder upstairs, because JayPee's car's powerband just stays the same from 6300 to redline using STOCK cam timing but BC cams.
Honestly though, seeing how much power 5.5s pick up with stock cams and 2.5" exhausts I bet you could hit 300whp SAE corrected on a DynoJet with LR MAF and a tune. The v-Manage would make your track slaughtering just that much sweeter
