Sponsored by:
Sponsored by: CARiD
Few Questions about installing a Fuel Cell
Old Sep 21, 2010 | 09:40 AM
t6378tp's Avatar
Turbo 3.5
I am looking to remove the stock gas tank and install a fuel cell in my 1997 Maxima. My question is will the stock intake setup with the sender drop right in or would I have to run an external pump.
I would really like to just reuse my walbro 255 and stock sender setup to cut down on noise and cost but don't feel like alot of custom modding either.
Old Sep 21, 2010 | 12:37 PM
grey99max's Avatar
LandShark has Cosworth
Funny - I've been shopping for fuel cells too, but kinda settled on a Jaz 2-QT Jr. Dragster cell for front mounting. A fuel cell in the rear requires a bulkhead installed if it's in the trunk. If you replace the stock tank, that shouldn't be required but everything big I looked at have the aircraft-style lid. That won't work for the OEM sender assembly, and you would need baffles mounted in the bottom if you did make it work, because of the slosh. Foam might fix the slosh.
The only thing I could see that would work is to mount a fuel cell in place of the OEM tank and use an external pump - and the OEM sender still wouldn't work without lots of hacking. I think you would also need an extension on the filler opening so you could refuel from the side - otherwise it's through the trunk. At some point I may put a cell in the trunk and make a NHRA-legal bulkhead, but that still needs an external pump, I think.
Too much work for me, right now.
Old Sep 21, 2010 | 02:39 PM
t6378tp's Avatar
Turbo 3.5
Yeah I was hoping this wasn't the case, not really worried about the sender since I can judge the tank by the trip-o-meter.
Hopfully they make a intake setup that will allow me to use my walbro 255
Old Sep 23, 2010 | 03:54 AM
Jime's Avatar
I am using a Jazz 8 Gal cell. The stock setup drops right in if you cut a hole behind the filler cap. Anything smaller than 8 gal and I don't think it would fit in. I get 200 mi range so it works fine.
I also have a 1 Gal that I previously used up front for my nitrous setup with a separate inline pump.
Currently my nitrous nozzles are being fed from a DevilsOwn pump from the stock windshield washer container.
Old Sep 23, 2010 | 08:56 AM
t6378tp's Avatar
Turbo 3.5
I know your running a full swap but was wondering if you tapped the top of the cell for a return line or you keep your system returnless. Also am I correct that your cell is foamless
Old Sep 23, 2010 | 09:31 AM
Jime's Avatar
My stock setup is from a 4th gen so return line is included however the cell does have its own return fitting. I do have my fpr external to the cell but mounted right beside it and it returns through the stock return so it is almost returnless.
I have run with and without foam, currently foamless.
Cotozic
Jun 28, 2017 08:01 PM
Quickgtp
Apr 13, 2017 03:30 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
niZ
Aug 7, 2015 10:18 PM
