Sponsored by:
Sponsored by: CARiD
Rev-up cam timing?
Old Nov 25, 2010 | 08:58 AM
Crusher103's Avatar
Rev-up cam timing?
The more i hear my car running the more i question using normal DE timing with these cams. Once its above 4500rpm the car really comes alive. but anything under that, at first i thought it was just the SSIM. But im not too sure listening to the car more and more.
When im driving around normally like around 3000rpm it sounds as if its misfiring. Plugs are all nice and dry. Since the motor is getting ready to come out(annoying O-ring oil leak) i can change timing. Torque is there It has quite a bit more than my stock AT, i just feel i could be a lot stronger.
Specs of cams:
Stock:
Engine: VQ30DE
Model Years: 1995-1999 (Maxima/ '96+ I30)
Intake__Lift: 8.55mm
Exhaust_Lift: 8.55mm
Intake__Duration: 232º
Exhaust_Duration: 232º
Intake_Opens: 3º BTDC
Intake_Closes: 49º ABDC
Exhaust_Opens: 49º BBDC
Exhaust_Closes: 3º ATDC
Overlap: 6º
Rev-ups:
Engine: VQ35DE (3)
Model Years: 2005 (G35 Coupe, 35th Anniversary 350Z)
CVTC: Intake and Exhaust
Intake__Lift: 10.5mm
Exhaust_Lift: 10.5mm
Intake__Duration: 248º
Exhaust_Duration: 248º
Intake_Opens: 2º ATDC
Intake_Closes: 70º ABDC
Exhaust_Opens: 70º BBDC
Exhaust_Closes: 2º BTDC
Overlap: -4º
Any ideas?
Old Nov 28, 2010 | 09:57 AM
Crusher103's Avatar
Nothing?
Old Nov 28, 2010 | 10:21 AM
MIKERNM1990's Avatar
check it:
http://www.jimwolftechnology.com/wol...INCL_REVUP.pdf
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
