Sponsored by:
Sponsored by: CARiD
Emanage blue on 5.5 gen
Old Feb 10, 2011 | 09:51 PM
azdevils013's Avatar
I have an Emanage Blue that I am trying to wire into my 5.5 gen. I have a few question about it and I am hoping someone has done this before. I am using Dandymax's writeup on the EU to wire the main harness in, but does anyone know if that is the only one I need, or do I need to buy a INJ or IGN harness as well and how would I wire those up? Also if anyone has any wiring diagrams or anything specific to the 5.5 for the EB I would appreciate it.
Old Feb 10, 2011 | 11:40 PM
maxgtr2000's Avatar
KH3 by popular demand
There is an emanage forum link in my sig, it has wiring diagram links there. I would definitely get the injector harness so you can log injector duty cycle and add fuel easier without altering timing. You can only retard timing with the ignition harness so you wouldn't really need it unless you are planning to run boost or nitrous.
Old Feb 11, 2011 | 07:48 AM
Thanks for the help. Is there wiring specific to the Maxima on there because I am having a hard time finding anything.
Old Feb 12, 2011 | 11:18 AM
maxgtr2000's Avatar
http://www.vqpower.com/v2/readarticle.php?article_id=26
Just double check the emanage wires and connect to your ecu.
http://www.thewrai6th.com/drop/Turbo/EMANAGE.pdf
Old Feb 12, 2011 | 04:38 PM
On Dandymax's writeup he shows a Connector B and C being used to wire the injectors. The emanage blue does not have anything that will fit the pin layout of Connector C so that would eliminate all of the OUT connections for the injectors and all I would only have IN connections. Does this mean that with the emanage blue I just have to splice into the injector wires instead of cutting into them?
Old Feb 12, 2011 | 05:43 PM
maxgtr2000's Avatar
Yes, you just splice into them.
Old Feb 12, 2011 | 06:24 PM
What will I be able to do with the injection if I am only tapped in?
Old Feb 13, 2011 | 01:20 AM
maxgtr2000's Avatar
You can increase pulsewidth without altering timing.
Old Feb 13, 2011 | 10:13 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
Wareagle92
Sep 3, 2015 07:18 PM
