Sponsored by:
Sponsored by: CARiD
4at to 6mt
Old Apr 19, 2011 | 09:12 AM
and1jr17's Avatar
4at to 6mt
03 maxima 4 speed auto to 6mt
The auto has been slipping in my 5.5 gen, and i figure if im gonna spend the money, i might as well make myself happy. I've got a rough idea of what the swap entails from what I've seen in some other threads, I have all my parts together.. but there are a few thing still unclear to me.
1. Are the bolts that go from the flywheel to crank the same as the bolts the go from flexplate to crank??? in other words can i use the same bolts i take from the auto or buy manual ones..
2. I see people talking about doing the rear main seal and upper/lower oil pan gaskets while the tranny is off.. the engine has 60k.. should I?
3. I'm not sure how to put the clutch pedal and master cylinder in.. Do i need to remove some part of the dash??
4. certain people say to always go oem with a throw out bearing.. so should i use the one that came with my exedy clutch kit or go oem??
Old Apr 20, 2011 | 05:36 PM
and1jr17's Avatar
no input?
Old Apr 20, 2011 | 06:03 PM
HotshotVQ35's Avatar
talk to the OP in this thread
http://forums.maxima.org/all-motor/6...6spd-swap.html
Old Apr 21, 2011 | 12:43 PM
NmexMAX's Avatar
dot dot dot ...
Not sure if any of these answer you questions but:
http://forums.maxima.org/5th-generat...you-shift.html
http://forums.maxima.org/5th-generat...ne-4-days.html
http://forums.maxima.org/5th-generat...care-only.html
Old Apr 21, 2011 | 02:55 PM
and1jr17's Avatar
thanks man, i saw these.. i just didn't want to get roasted for waking up 4 year old threads..
Old Apr 21, 2011 | 02:56 PM
and1jr17's Avatar
and i figured out the flywheel and flexplate bolts are different btw
Old May 8, 2011 | 06:18 AM
Grand_hustle17's Avatar
For the most part its the same as a 5spd swap... you are most likely gonna hae to go by the dealer for a part of the trany mount, its a 2pc mount I wanna say the part number is 11253 or 6, if you can find the diagram the dealers use for part numbers I can easily point it out 2 you..., your gonna also have to cut off the auto tranny mount (carefully) and use spacers n and some really strong bolts to put the 6mt tranny mount on...
Old May 8, 2011 | 09:27 AM
and1jr17's Avatar
thanks for the response bro... just picked up a bunch of misc bolts that i was waiting on.. I'll prolly start the swap this weekend.. i have both pieces for the tranny mount already..
Old May 8, 2011 | 09:31 AM
and1jr17's Avatar
swapped my brake pedal.. also drilled and mounted the clutch pedal and master cylinder..
Old May 8, 2011 | 09:53 AM
O.k cool, seems like u have everything in place then, good luck n keep us posted
Old May 8, 2011 | 12:11 PM
and1jr17's Avatar
While I have your attention.. Are there any other issues you ran into with your swap?
Old May 8, 2011 | 06:42 PM
Mmm naw, I doubt it will be an issue for u... from time to time I lose pressure in my clutch to where I damn near have to pump it up a few times, I've canged master and slave cyl and still the same result, its gotten better but ever so random I will looe pressure in the clutch more so when I'm cruising in 6th on the hwy then when I get off, huge flat/dead spot in the clutch pedal, I think I still have a faulty master cyl though so we will see... other than that.... nothing but fun
Old May 8, 2011 | 07:48 PM
aackshun's Avatar
Jon, where are you? you're always stalking the org for these types of threads....
Old May 9, 2011 | 12:38 PM
and1jr17's Avatar
Hmmm I see I see.. You using stock lines?... I've been told that once you get air into it; you'll never get back the stock feel.. I bought the one piece stainless steel line.. Which eliminates a bleeding point... Also.. What kind of clutch set up ?
Old May 10, 2011 | 08:45 AM
I've got a stainless steel clutch line and excedy clutch.... oh quick question for you.... do u plan on using the auto ECU? If so and you plan on wiring up your reverse lights keep me posted with pics, I just wanna know what exactly is the reverse lamp switch on the trans and exactly what wire to connect to what
Old May 10, 2011 | 06:11 PM
and1jr17's Avatar
Something isn't right there.. Anywho.. I do have my 6 speed ecu.. But no keys.. So I'll have to go thru the hassle of getting it towed and reprogrammed.. My main concern is the swap right now.. That being said I plan on using the auto ecu to begin with... I found some threads on nycmax on how to wire in the reverse and pnp swich using an auto ecu; so we'll see how that goes.. Keep you posted
Old May 12, 2011 | 06:43 AM
Yup... my 5.5 dilemma... only me, only me
Old May 13, 2011 | 07:49 AM
and1jr17's Avatar
did you have to drill a bigger hole for the shift cables?
how did you mount the shift assembly? the studs on the body aren't long enough..
grand hustle. pm me your number please.. need some info
Old May 14, 2011 | 06:01 AM
Gotta shoot me pms bro, I'm hardly in this section.... 301 254 4088 (I personally didn't do my swap but can get just about all most of the info for you)
If you check out aackshun's blog and thread on the 6spd swap there should be pics of what ur talking about n how its done... I do believe that a bigger hole was drilled though
Old May 24, 2011 | 10:22 AM
and1jr17's Avatar
the car is together and running!!
the only two issues i have right now..
1. i have a front end shimmy at 60mph and up.. but only under acceleration.
2. the motor mounts are wayyyyyy soft.. im going to go over everything and make sure its properly tightened..
any input / ideas?
Old May 25, 2011 | 04:32 AM
Congrats... lil late for 5.5's to be doing maual conversions but non the less I hope ppl don't get so afraid doing this.. hopefully after surratt is finished with that 09 motor we will start seeing more of these down the pipeline... cause if one of these DCmax heads wanna give it a try then its definately suttn I wanna try
Unclejunebug
Apr 2, 2016 05:42 AM
Derrick2k2SE
Aug 12, 2015 06:47 PM
MikesChevelle
Aug 7, 2015 05:57 PM
MikesChevelle
Aug 6, 2015 11:36 AM
