Sponsored by:
Sponsored by: CARiD
what do i need to run revup cams
Old Jun 19, 2011 | 08:06 PM
bds1304's Avatar
hey guys i found a real good deal on a set of rev up cams.....what do i need to run them, and what other stuff do ya suggest i do also?
Old Jun 19, 2011 | 11:06 PM
shrek's Avatar
wait,have you finished all your bolt ons??? the way i see it ...cams are one of the last steps on a N/A maxima....or maybe you should post your parts list first and will go from there.....
long story short ,you will need HR springs and a rev up oil pump and raise your limiter to enjoy the top end power,and will only feel good if you have done all of the good bolt ons (SSIM,3" exhaust,BB maf and a tune)
Old Jun 20, 2011 | 06:47 AM
bds1304's Avatar
well so far i have a custom im, and 2.5 exhaust......but i have my car in the shop, so when i pull out my engine i wanna do some more work to it like headers, custom y pipe, custom 3inch......new clutch and lw flywheel. after all that im going with 3.5 intake with intergrated maf housing. but i guess ill work that stuff into my budget.
Old Jun 20, 2011 | 09:31 AM
NmexMAX's Avatar
dot dot dot ...
Extended rev limiter is a must
HR valve springs and double shims are suggested
Supporting mods: Headers are also a must, larger MAF housing is a must, SSIM should be a must.
Old Jun 20, 2011 | 12:04 PM
ajcool2's Avatar
+1
Old Jun 20, 2011 | 04:31 PM
bds1304's Avatar
i have the ssim under control......but everything else is gonna be put on when i pull my motor back out then its gonna get dyno tuned.......
Old Jun 21, 2011 | 02:39 PM
maxspeed96CT's Avatar
The original VQ...
This may sound like a silly queston, but would it be worth it just to swap in a motor from a rev-up ?
Or is it to much work ?
I see alot of of recked g35s and 350's out there.
Instead of messing with the cams and etc...
Old Jun 21, 2011 | 07:18 PM
bds1304's Avatar
to much work plus i already swapped my motor once dont wanna buy another one.......i think i got the deal of the century for that motor too......can u say 450 for a 54,000 mile motor
Old Jun 22, 2011 | 09:41 AM
ajcool2's Avatar
In the stickys. http://forums.maxima.org/all-motor/5...s-lengthy.html
Old Jun 22, 2011 | 12:43 PM
pmohr's Avatar
No more Maximas...
Originally Posted by ajcool2
Hard to believe that was more than 3 years ago...
Old Jul 28, 2011 | 09:21 AM
ranmas2004's Avatar
You might want to add some ARP rod bolts in as well if you are going to raise rev limiter.
spazma7ik
Jan 12, 2017 09:38 PM
captchaos
Mar 15, 2016 12:18 PM
gustavison
Oct 4, 2015 06:50 PM
JoshG
51
Sep 21, 2015 10:41 PM
conansriver
Sep 11, 2015 10:26 AM
