Sponsored by:
Sponsored by: CARiD
Request from 00vi Drivers
Old Aug 7, 2011 | 04:25 PM
shadyonedeath's Avatar
I need you to warm up your car, turn it off, unplug your TPS (brown connector), turn car back on, and report your base idle as it is right now.
Just seeing where I stand with my 1300rpm base idle and not being able to figure it out despite numerous gaskets and vacuum tests and new IACV parts.
Please and thank you.
Old Aug 7, 2011 | 05:00 PM
danmack34's Avatar
just adjust it thru the screw on your throttle body see if it helps ill check back if i remmeber this thread
Old Aug 7, 2011 | 07:50 PM
Weimar Ben's Avatar
Helicopters! Money!!!
1300 rpm idle isn't that bad. Try dealing with a problem where sometimes it idles at 3000 rpm and sometimes not at all, despite having replaced a MAF 3 times, O2 sensors, and ECU.
Old Aug 7, 2011 | 08:26 PM
mista0406's Avatar
I would chime in but I don't think a boosted max could give you the readings your looking for i thought you had this problem fixed by now???? Good luck bro on finding out whats happening
Old Aug 7, 2011 | 08:40 PM
MOHFpro90's Avatar
Will do tomorrow, if I can remember.
Old Aug 8, 2011 | 09:25 AM
ajcool2's Avatar
If I stil had a 00VI'd max I would.
Old Aug 8, 2011 | 03:04 PM
MOHFpro90's Avatar
Revved up to 2200 ish at startup. Dropped down to 800 ish after 5 seconds.
Old Aug 8, 2011 | 07:06 PM
Weimar Ben's Avatar
Which IACV are you using? The 00 IACV kinda sucks with the A32 ECU
Old Aug 8, 2011 | 07:25 PM
mista0406's Avatar
^^^^^^ I beg to differ. Only in few max's (why? I don't know) but a few, including me, have used the 00vi iacv and worked flawlessly.
Old Aug 8, 2011 | 10:08 PM
4th gen iacv
Old Aug 9, 2011 | 06:34 AM
ajm8127's Avatar
If you remove the IACV from the body and cycle the ignition from off to on, you should see the plunger on the valve move in and out. What ID tubing are you using to and from your remotely mounted IACV?
Old Aug 9, 2011 | 11:13 AM
the tubing is 1/2" ID. and its only about 3 inches long.
Old Aug 9, 2011 | 05:56 PM
MOHFpro90's Avatar
I am using the 00 IACV. Works great.
Old Aug 10, 2011 | 06:17 AM
aackshun's Avatar
Hrmm, I could throw mine on and test it out for you lol.
Old Aug 10, 2011 | 08:36 AM
ajcool2's Avatar
+1
Old Aug 20, 2011 | 10:50 AM
5th or 4th iacv? That's weird, mine just stays open at 1300+
Old Aug 20, 2011 | 10:52 AM
Nevermind mofPro.
Anyone else have readings to share?
user 11122324
42
Jul 18, 2022 03:35 PM
BobTX10
Oct 7, 2015 08:43 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Noela
Sep 26, 2015 08:22 AM
