Sponsored by:
Sponsored by: CARiD
The Definite BBMAF Thread
Old Aug 16, 2011 | 05:25 PM
McSteve's Avatar
I think we should sticky all the compiled information about BBMAFS. Similar to the Cam specs we should get pictures and the dimensions of various MAFs.
My secret motivation to this thread is to clear up confusion. I bought a LR MAF on ebay only to find out that it's the exact same ID as my 2k1 maf. Now I don't know whether that's how it's supposed to be or if it's because I replaced my MAF with an Autozone one like 2 years ago.
4.6L LR MAF ID was 2.5x" OD close to 3"
2k1 Maf and Injen Adapter plate ID also 2.5x" OD close to 3"
EDIT:
The correct LR Maf is for the 4.4l
Old Aug 17, 2011 | 03:14 PM
NmexMAX's Avatar
dot dot dot ...
Weird, post pics of this alleged LR MAF.
One way to ensure it's the right one is also to cross reference it to an M62 MAF. (BMW).
From what I recall too is the LR HSE model. I find it strange the 4.4L version wasn't the correct unit. Where (eBay seller) did you order this from? perhaps you need the 4.6L piece.
Comparing the OEM and correct LRMAF together is laughable, the OEM will literally fit inside the LRMAF if it wasn't for the sensor bolt pattern on top.
The ID of the LRMAF is ~ 3.25".
Old Aug 17, 2011 | 03:31 PM
SurraTT's Avatar
HR Swap Pioneer
Other than LR maf what else are ppl using??? Ill be messing with intake stuff soon. seems that 3.5 tubing and lr maf are good as it gets? What about a 3.5 maf to match the 3.5 piping?
Old Aug 17, 2011 | 03:53 PM
NmexMAX's Avatar
dot dot dot ...
My tubing is about the same ID as the LRMAF. This is the tubing from siliconeintakes.com. The LRMAF is 82mm and the tubing from there is 85.6mm according to their specs (wall thickness of 1.651mm)
There's a Bosch unit for a Mustang, the 99+ 4.6L that has 260 hp. It's a 77mm unit.
knight could make you one (76.2mm).
IMO, the LRMAF + 3.5" tubing is the best for us (02-08VQ35). BUT, as you've noted in your swap thread the TB and A35IM port are quite a bit larger, even larger than the L32 Altima.
So who knows about you man.
Old Aug 17, 2011 | 04:05 PM
SurraTT's Avatar
HR Swap Pioneer
^ cool thanks for the info!!!
Im thinking of using the LRMAF and 3.5 intake tubing, when i do it.
And i totally agree the 09 motor might benefit from even larger than this. I seen that site has 4.0 piping also. All i know is the stock maf and intake is probably killing my power right now.
Old Aug 18, 2011 | 10:49 AM
McSteve's Avatar
It actually was the 4.6L one...
http://cgi.ebay.com/ebaymotors/_W0QQ...ht_6108wt_1167
the compatibility chart is silly.
It is pretty much an exact OEM 2k1 replacement only it has the thermistor integrated and has a a clampable end instead of the bolt pattern.
I guess what i'll do is I'll machine a socket for the maf onto the silicone intake tubing...
Old Aug 18, 2011 | 10:50 AM
NmexMAX's Avatar
dot dot dot ...
I apologize for that, since I should have included this in my thread long ago.
Old Aug 18, 2011 | 02:04 PM
McSteve's Avatar
@SurraTT
I could possibly make you a custom 4" intake with included inbuilt maf adapter.
I'm gonna build something like knight_xyz did out of the existing silicone intake pipe. My uncle has a 2 axis CnC so it shouldn't be a problem making that little maf socket and welding it onto the SiliconeIntake tube
Old Aug 18, 2011 | 02:21 PM
SurraTT's Avatar
HR Swap Pioneer
^ sounds interesting. I would be interested in a 4" intake with built in maf adapter. I think it has to be a certain height off the tube tho.
Old Aug 18, 2011 | 03:16 PM
McSteve's Avatar
well yeah. the difference in the radii has to be subtracted from the socket.
Old Aug 19, 2011 | 06:14 PM
maxima dude's Avatar
ill be making a 1piece full 3.5 inch intake with maf adapter
Old Aug 21, 2011 | 08:03 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
if you've seen my 3 inch mag setup, I'm basically having a local guy replicate that n a 3.5 with bpi velocity stack. Bloc makes a 4inch stack as well if u want I can check on one for u. Will have an integrated aluminum block for the mad as well
Old Aug 21, 2011 | 08:05 AM
Chocolate_Boi_1Der
Shoulda read the whole thread....hmmm ....s
Old Aug 23, 2011 | 06:00 PM
white_spec-v's Avatar
does the stock maf clip plug right into the lrmaf?? im confused if it does or doesnt
Old Aug 24, 2011 | 01:16 PM
McSteve's Avatar
you need to remove the torx screws and mount your sensor into the housing.
Old Aug 24, 2011 | 01:34 PM
oooo ok. gotcha, thanks!
Old Aug 31, 2011 | 08:58 AM
cardana24's Avatar
Blown
this may be a stupid question, but is this only applicable for 5th gen MAF's? I have an A32 MAF set up that I would like to run a larger MAF housing on.
Old Aug 31, 2011 | 08:59 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/4888978-post76.html
http://forums.maxima.org/all-motor/5...usly-lean.html
http://forums.maxima.org/all-motor/5...on-advice.html
There might be more
Old Aug 31, 2011 | 10:05 AM
95naSTA's Avatar
I just bought an aluminum version of that off 97Maximus here with a 3" MAF screen that was pressed in before the sensor. There's definitely some mid-high end gain. Quite a bit of fueling had to be added too. Makes sense, just wanted to reiterate tuning is needed.
Old Aug 31, 2011 | 10:09 AM
NmexMAX's Avatar
dot dot dot ...
If staying NA, I'd suggest 3.5" intake.
Old Aug 31, 2011 | 10:40 AM
shrek's Avatar
can you use the Q45 maf on a 4th gen??? it would be big bore and you would only need to tune
Old Aug 31, 2011 | 11:03 AM
NmexMAX's Avatar
dot dot dot ...
It's been kicked around but never executed and if it was, never documented on here.
http://forums.maxima.org/all-motor/5...i-q45-maf.html
http://forums.maxima.org/all-motor/550019-q45-maf.html
http://forums.maxima.org/all-motor/5...f-a32-ecu.html
http://forums.maxima.org/supercharge...?highlight=Q45
Old Aug 31, 2011 | 01:20 PM
McSteve's Avatar
is the z32 maf able to measure more voltage than the A33? I bought a m62 maf that someone sold cos the sensor was broken for $20 (yay).
But should i ever go FI, will i need to change the maf again or should the stock maf in a bigger housing be able to handle all the air?
Old Aug 31, 2011 | 03:03 PM
NmexMAX's Avatar
dot dot dot ...
Ummm. An A33 MAF is sorta limited only by the diameter of the housing that it's in, meaning it can be made to read less voltage, even though more air is coming in.
Unklejoe maxed his out IIRC w/ his turbo set-up, check out his thread in the FI forum, but he was using the stock housing IIRC.
Z32 MAF can read more air given its fixed state unlike the A33 sensor, i.e. if the A33 sensor was in the same diameter housing as the Z32 > A33.
Old Sep 5, 2011 | 02:37 PM
SurraTT's Avatar
HR Swap Pioneer
So i ordered a LR maf and i too received the unit thats the same as stock.
Very confused as to WHICH is the bigger one.
here is the one i got
http://cgi.ebay.com/ebaymotors/_W0QQ...KQ3aMEWNXQ3aIT
It says 4.6L HSE
can someone get more accurate details as to which years/motors has the bigger maf??
Old Sep 5, 2011 | 09:08 PM
knight_yyz's Avatar
Toolie
Here's mine before the ceramic heat barrier coating. 80mm ID extruded aluminum, with vibrant velocity stack. OD is only 85mm thus the rings to make the OD an even 3.5" for standard silicon couplers. Total length with velocity stack is ~ 17".
Guys, please don't ask me to make you one. This is a huge job to do when I am working full time and the extruded aluminum is a ***** to find. The turbo piping that everyone wants to use is too thin for me to weld. The big thick block for the MAF sensor shelf takes a crap load of heat to get the filler rod to melt, and will most likely blow holes in the turbo pipe. It's beyond my expertise until I can take some lessons and have access to a much better welder.
Ceramic coated without the velocity stack.
Old Sep 12, 2011 | 02:51 PM
SurraTT's Avatar
HR Swap Pioneer
Old Sep 22, 2011 | 11:21 AM
2000_MAXIMA_KING's Avatar
Good ish , almost bought the wrong one
Old Sep 26, 2011 | 07:52 AM
LR part# MHK000230
Bosch part# 0 280 217 814
BMW part# 13 62 1 433 567
i used the LR part# to get mine on ebay. make sure it is for the 4.4l
Old Sep 26, 2011 | 09:31 AM
maxboy325's Avatar
Have at it. NOT MINE
http://cgi.ebay.com/ebaymotors/BMW-5...item33685a0b59
Old Sep 26, 2011 | 01:16 PM
is there any way to take off that plastic 'screen'?
Old Sep 26, 2011 | 02:36 PM
SurraTT's Avatar
HR Swap Pioneer
itll cut off, but ima just leave it. i think itll make airflow flatter right before the maf sensor.
Old Sep 26, 2011 | 02:48 PM
Whay would you want to remove the screen
Old Sep 27, 2011 | 08:35 AM
unrestricted airflow.. my car is an all out drag car.
and this lrmaf has two screens. the thin metal screen, and a thick plastic screen. i dont like the plastic one
Old Sep 27, 2011 | 08:40 AM
oh didnt realize it had an extra screen as well, good to know.
can you just punch it out
Old Sep 27, 2011 | 09:20 AM
maybe, i only looked at it real quick, but i think i saw 3 or 4 'clips'. might be able to just take it out without breaking anything.
Old Sep 27, 2011 | 04:15 PM
MoncefA33's Avatar
Those screens do not disrupt airflow. They take turbulent air and allow the flow to be more laminar/smoother which actually makes power.
Old Sep 27, 2011 | 04:32 PM
What would you know about power
Old Sep 27, 2011 | 04:41 PM
SurraTT's Avatar
HR Swap Pioneer
YA kinda what im thinking. ima leave the screens as is.
Old Sep 28, 2011 | 11:20 AM
NmexMAX's Avatar
dot dot dot ...
Laminar flow, magic phrase from the early org days. Th LRMAF one is pretty intense.
Why you ask ....
Because race car
