Sponsored by:
Sponsored by: CARiD
cam ?
Old Aug 24, 2011 | 07:15 PM
Flava_24/7's Avatar
Boosted Panda
cam ?
So Im having some rev up cams put it with Stephen Max's cam adapters, and I got a call from the shop telling me the lobes on the 3.5 cams dont line up like the 3.0 cams. I thought using the cam adapters corrected them to sit in the 3.0 position?
Are they lining them up wrong or something? Here are some pics I have....
Anyone have any insight? Im really hoping there isnt an issue so that they can complete the work tomorrow morning.
Old Aug 24, 2011 | 10:25 PM
McSteve's Avatar
are they putting the right adapters on the right cams?
intakes is adapter, exhaust is spacer i believe. somebody should confirm that tho.
the intake cam should have a drill mark
Old Aug 25, 2011 | 05:48 AM
ajm8127's Avatar
The spacers have nothing to do with how the lobes line up. The journals control where the lobes are positioned. The spacers only bring the timing chain in line on the 3.0.
I have a 3.0 in about 1000 pieces and some rev up cams at home. I can do a sanity check later but I'm pretty sure people put cams from the vq35 in the vq30 all the time.
Old Aug 25, 2011 | 08:35 AM
Flava_24/7's Avatar
Boosted Panda
Well, I know some have put them in but theres not too much info on hwo has and etc.
So I guess I will tell them to go ahead and just install them and hope everything works out.
FINGERS CROSSED
Old Aug 25, 2011 | 03:10 PM
ajm8127's Avatar
Here are vq30de cams next to rev up cams. The bottom of the picture is the front of the engine. The lobes are in perfect alignment.
I suspect the guy at the shop was using bank 1 cams on bank 2 or vice versa. That will cause a lobe misalignment.
Here are the bank 1 rev up cams in a bank 1 vq30de head:
Looks good to me. Maybe one day this will be done. I'm working on cleaning the other head and valves now, then i'll do a little lapping to clean up the sets. I'm getting pretty close to putting it all together.
Old Aug 25, 2011 | 06:08 PM
McSteve's Avatar
how do you tell bank 1 from bank 2? by comparing the alignment to the stock ones?
Old Aug 25, 2011 | 07:09 PM
SurraTT's Avatar
HR Swap Pioneer
The length from the end of the cam to the first lobes.
Bank 1 is short.
Bank 2 is longer
shows bank 2 see how from the end to the first lobes is quite long, bank 1 is a lot shorter
Old Aug 25, 2011 | 07:32 PM
Crusher103's Avatar
thats alittle weird, im running them and the duration of them seems to have moved the lobes alittle bit compared to the normal 3.0 cams but they worked fine in my car. Ask him if he is sure its for the correct bank. They wont even fit if they are not in the correct bank.
Old Aug 25, 2011 | 07:42 PM
Crusher103's Avatar
Actually you might want to go stand and watch while those cams are being installed. Im dead sure they fit and work with out issue unless they are not rev-up cams.
The lobes on bank 1, cylinder 1 are suppose to face upward and towards each other and its the little hole on the cam is the one that face upward on the intake cams The arrows on the timing chain are suppose to point at the 2 blue links on the chain, And the gold like has to line up with the arrow on the crank's gear.
If they are making a mistake like that. They have already started but you might want to keep your eye on that.
Old Aug 25, 2011 | 08:21 PM
Flava_24/7's Avatar
Boosted Panda
I spoke to Stephen Max and he educated me on the cam spacers. He told me "he makes the adapters with a 4 degree advance angle compared to the VQ30 cams. The four degrees results in the same intake-exhaust valve overlap as the VQ30 setup. This is done because the exhaust valve opening and closing times are different between the VQ30 and the VQ35."
Im pretty sure their Rev Up cams, I bought them from another member here and they seemed to be a legit seller, they have the notches in the ends of them also....
When I spoke to them, they hadnt tried to install them. They were just comparing them to the OEM cams. I plan on stopping by tomorrow to see whats going on.
Sending you a PM Crusher.
Old Aug 25, 2011 | 08:42 PM
Crusher103's Avatar
gotcha.
Old Aug 25, 2011 | 09:13 PM
Flava_24/7's Avatar
Boosted Panda
Crusher, you rock man. Big thanks for that detailed info bro. That should resolve any issues or questions that may arise.
Old Aug 25, 2011 | 09:44 PM
Crusher103's Avatar
No problem man.
Old Aug 29, 2011 | 12:23 PM
McSteve's Avatar
ny updates?
i'm interested to see how the rev ups will work with your supercharger.
aaand a dyno slip : )
Old Aug 29, 2011 | 06:41 PM
Flava_24/7's Avatar
Boosted Panda
ny updates?
So am I, but all in due time.
Once the build is complete I will need to have it tuned, then work on extending the rev limiter for a final tune. Hopefully it will all be said and done in a few more weeks.
Old Sep 23, 2011 | 06:35 PM
McSteve's Avatar
so what it is, sucka?
well overdue for an update : )
Old Sep 25, 2011 | 10:24 AM
wirelessdude04's Avatar
In for the finished results
Old Nov 3, 2011 | 07:32 PM
J2FRESH's Avatar
bump update this bish flava or else
Old Nov 4, 2011 | 05:02 AM
Flava_24/7's Avatar
Boosted Panda
Not mch to update.
Car is up and running, just finished breaking in the motor and new clutch, now Im gathering the funds to have it dyno tuned.
Once its up and running 100% I will post more.
Im not one to posts up and say " Hey,Im gonna do this and this and etc." and then later never follow through like some on here do. Thats why Id rather wait until everything is done and then post up.
Old Nov 4, 2011 | 09:47 AM
McSteve's Avatar
how about the butt dyno tho? any first impressions?
Old Nov 4, 2011 | 10:18 AM
Flava_24/7's Avatar
Boosted Panda
Well like Ive stated I just gone done breaking in the motor and clutch so none of my revs have been above 3500 so I couldnt really tell you.
Plus without it being tuned Im not about to start beating on it.
Old Nov 5, 2011 | 04:57 PM
t6378tp's Avatar
Turbo 3.5
so you rebuilt the motor too or did a 3.5 swap
Old Nov 5, 2011 | 05:57 PM
maxspeed96CT's Avatar
The original VQ...
love threads like this , keep us updated
Old Nov 6, 2011 | 02:29 PM
Flava_24/7's Avatar
Boosted Panda
Rebuilt the 3.0, nothing too extreme though.
Trying to schedule a tuning session now, hopefully my tuner will be available soon.
Old Nov 24, 2011 | 10:16 AM
t6378tp's Avatar
Turbo 3.5
Any updates
Old Nov 24, 2011 | 10:40 AM
Flava_24/7's Avatar
Boosted Panda
Any updates
http://forums.maxima.org/members-rid...ew-pics-3.html
Old Nov 25, 2011 | 04:17 AM
t6378tp's Avatar
Turbo 3.5
what headgasket did you go with
spazma7ik
Jan 12, 2017 09:38 PM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
conansriver
Sep 11, 2015 10:26 AM
