Sponsored by:
Sponsored by: CARiD
specv trans, fidanza flywheel, but what clutch?
Old Oct 26, 2011 | 12:28 PM
grksoccerkid91's Avatar
So my 3rd gear is grinding and since I'm doing exhaust and need a clutch might as well do it all.
I picked up an 05 sentra specv trans and a fidanza flywheel but what clutch do you guys recommend for good street use but also keeping in mind I beat on the car and will autox and drag it next year..
My mods:
GAB, SSIM, cattman headers (to be installed), nwp spacers, and a custom 3in once I get my headers in. I MIGHT get some jwt s2 cams if my friend sells them on the cheap side as well.
Also, is there a writeup or any tips on how I should swap bellhousings??
Summary: I plan on tracking the car, autox and drag, have a specv trans and fidanza flywheel and want a clutch that can pair up right and be good for both aspects.
Old Oct 27, 2011 | 06:04 AM
tuko316's Avatar
Jwt stage 1
Old Oct 27, 2011 | 06:39 AM
ranmas2004's Avatar
For what you plan on doing I would NOT recommend a jwt stage 1 clutch or ANY stage 1 really. If you read JWT website it says that if you use their clutch that you HAVE to use their flywheel too, but you already have fidanza flywheel so that JWT stage 1 will not work with it just by reading the website.
I have a SPEC Stage 2 clutch and fidanza flywheel on my maxima. I would recommend that to you as well....a SPEC stage 2 clutch for the Sentra its good for 241 ft-lbs and if you want you can get the SPEC stage 2+ which has the same drivability but is good for 270 ft-lbs. (in case in the future you plan on doing some more building to your car). I can tell you from experience with my SPEC clutch its VERY VERY streetable...I drive the car everyday to work no problems at all no chatter nothing. Easy to drive and feels MUCH MUCH better than that SOGGY stock clutch! It's nice and tame when I want and then when I want to get on it that thing GRABS...HARD!!
Old Oct 27, 2011 | 09:53 AM
aackshun's Avatar
Be cheap like me, OEM tree-fiddy-zee.
Old Oct 27, 2011 | 10:25 AM
for the longest time i was set on the 350z clutch, but then i realized i'm going to be beating the **** out of the car next year, as much as i dont want it its uh, "natural" haha.
how much do the 350z clutches usually hold? how much abuse do you guys think they'll take with my listed mods?
i should still get a spec stg2 clutch for the maxima though correct? since i'm changing out the bellhousing i'd still use the maxima stuff? this is my first manual (that i own and have to replace stuff myself, i've driven em forever, just never been my problem lol) so isn't the clutch more related to the motor rather then trans?
i searched on google and some random sentra forums about swapping bellhousings, everyone says they've done it, but no one says how =[ if its something simple i'll be able to do it at the dealer i work at, but if itll take more then 2 days to pull it out and put it in i can't do it there. i've never done a manual trans so idk.
Old Oct 27, 2011 | 10:33 AM
tuko316's Avatar
Jwt stage 1 is good for 400+ according to them. They have customers with turbo Z's using this clutch with no issues. I had it on my car (~260whp) for 2+ years and no issues. Feels and grabs like stock.
Old Oct 27, 2011 | 10:48 AM
ranmas2004's Avatar
OK...Im confused.....you got a Maxima with a SPEC V tranny???? you doing some kind of manual conversion on it? Im thinking you had a SENTRA SPEC V......
Whatever.....SPEC Stage II......you wont regret it!
Old Oct 27, 2011 | 02:56 PM
aackshun's Avatar
Just pretend you shortened the gears on your transmission via final drive and add HLSD (if you didn't have it).
And Z clutches are good until you approach near 300.
And I abuse the **** out of mine, even though I only make about 210wtq
Old Oct 28, 2011 | 01:26 AM
tsaulz's Avatar
I'm selling a JWT clutch with only 3k miles on it for $400 OBO. I had it paired with a Fidanza flywheel, and it was amazing -- so much grip.
Sadly, the car's gone, but here's the part out thread with more info: http://forums.maxima.org/4th-generat...ory-parts.html
Old Oct 28, 2011 | 08:42 AM
ranmas2004's Avatar
OH now I understand. I already have HLSD!!!!
Old Oct 31, 2011 | 08:21 AM
Hah ya, sorry for not being clear on the specv tranny thing. I talked to someone local who did a vq35 swap on his sentra, is it true that I need a maxima lsd bellhousing or will my maxima w/no lsd bellhousing work?
Old Dec 27, 2011 | 05:46 PM
02max245's Avatar
Pretty sure Ghustle did the spec v tranny swap on his GLE, talk to him
Old Dec 27, 2011 | 09:14 PM
Nealoc187's Avatar
SLOW
i know this is an old thread, but the 350z jwt clutch held 430lbs of torque for 3 years on a 350z i built. that car was raced at every opportunity (it ran mid 11s on DRs). i was thoroughly impressed by the JWT 350z clutch.
i wouldn't ever get a spec clutch, and i would never advise anyone else to get one either.
Old Dec 28, 2011 | 06:43 AM
aackshun's Avatar
This isn't the 5MT days anymore, the housings are the same, it's all in the differential now.
You can get any 6mt diff, just make sure the drive ring matches whatever is on the output shaft.
(So if your transmission is a 3.7 make sure you put the 3.7 ring on your diff).
Old Dec 28, 2011 | 07:01 AM
Grand_hustle17's Avatar
naw, i didnt have anyone to swap bellhousing.... i know sparksmax03 did it though
Old Dec 29, 2011 | 09:59 AM
krazy6's Avatar
I have spec v internals in a non-lsd maxima bellhousing. I'm also using the back half of the sentra case. Only maxima parts are the bellhousing and the shifter.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
