Sponsored by:
Sponsored by: CARiD
rev-up oil pump good for AT 4th gen motor?
Old Nov 4, 2011 | 09:35 AM
atriuum's Avatar
Question rev-up oil pump good for AT 4th gen motor?
There's relatively little on this when searching for "oil pump" or "rev-up". Can I put a rev-up pump on a vq30. The pumps are standard on 300zx's right?
Old Nov 4, 2011 | 09:56 AM
I don't see why not. I hope you have supporting mods.
Old Nov 4, 2011 | 10:33 AM
atriuum's Avatar
Smile
I won't pretend I know what you are referring to. Which supporting mods do you mean?
Old Nov 4, 2011 | 10:38 AM
mightyMax95's Avatar
Originally Posted by atriuum
There's relatively little on this when searching for "oil pump" or "rev-up". Can I put a rev-up pump on a vq30. The pumps or standard on 300zx's right?
short answer, yes. no reason to unless you have a raised rpm limit, but it won't hurt either.
Old Nov 4, 2011 | 12:27 PM
atriuum's Avatar
So basically when the other poster said he hoped I had "supporting mods", he meant it's a lot of work for little benefit if I don't have the car juiced up; other than having a better oil pump, a rev-up won't do anything for me...
It would just be a better pump.
Is it possible to install it without raising the engine? Or is that out of the question.
Old Nov 4, 2011 | 01:42 PM
unless your pump is already broken, it's pointless. you'll have to pull the engine and remove the timing chain cover. this is possible without removing the motor, but it's VERY difficult.
Old Nov 4, 2011 | 09:05 PM
It's not worth the time/money/labor if you're stock.
Old Nov 7, 2011 | 04:34 PM
ajcool2's Avatar
Searched for 5 seconds on google and found this http://forums.maxima.org/all-motor/3...-oil-pump.html. Make sure you read the whole thread. Also lookup dandymax you'll learn alot. I have a revup oil pump in my gf's 3.5 right now with ARP rod bolts.
Old Nov 19, 2011 | 09:30 AM
atriuum's Avatar
Thanks for the thread link. I have a question, does the rev-up pump have a higher movement of oil? Does it move more quarts per minute even at low rpms? I can't find the specifications anywhere.
Old Nov 19, 2011 | 01:00 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Pretty sure the 2 pumps are almost identical aside from the revup having stronger internals. Someone posted pics/analysis between the 2 on the Z forums... cant remember where.
Old Nov 19, 2011 | 03:11 PM
ajm8127's Avatar
I'm guessing that the Rev-up pump may be made to tighter tolerances and may be balanced better, aside from being different materials. Buts thats just speculation.
It was Arron from NWP that took one of each apart for comparison purposes. http://forums.maxima.org/all-motor/5...oil-pumps.html
The tread says the spring inside is difference as well. I'm thinking that it regulates the pressure of the oil.
All I know is that I would not put one in my car unless I was building an engine, which I am
Old Nov 19, 2011 | 03:13 PM
atriuum's Avatar
I had already found that thread and looked at the physical differences. My question was whether in addition to better materials/construction, does it move more oil at all rpm?
Old Nov 20, 2011 | 06:34 AM
ajm8127's Avatar
The FSM for the 2005 350Z makes no distinctions between the oil pressure for the rev-up and non rev-up models (See the LU section). However, the specification only lists pressure at idle and 2000 rpm, so who knows what happenes to the pressure a 6 or 7k rpm.
The spring for the regulator value is noticeably different from Aaron's dissection, so it quite possible could be set at a higher pressure.
It's very difficult to get a 1:1 comparison between the two pumps. One would need a dyno, an oil pressure gauge, and equal bearing clearances on the inside of the motor (ie. the same motor). Just because you have a vq with 100k miles, and you rebuild it with the rev-up pump and notice an increase in pressure doesn't mean the pump makes more pressure. It could be that the bearing clearances are tighter on your newly rebuild motor.
The point is no one knows and it would be difficult to get a proper comparison. Nissan decided to use the rev-up pump in a higher performance version of the vq35, so a lot of people feel that when building a high performance vq30 or vq35, the rev-up pump makes sense. But without knowing exactly how the pumps are different, this is all just speculation.
Personally, I'm still going to use one in my 7k+ redline vq30, but unless you plan to up your rev limit (which is pointless unless you have intake, cams, headers, exhaust, engine management etc.), I'd have to say the stock pump is adequate.
Old Oct 31, 2012 | 01:37 PM
catalinvint's Avatar
Any suggestions on which to buy. Links to other rev-up oil pumps or which ones will fit the VQ30DE engine.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Finkle
Sep 27, 2015 09:53 PM
VQ'ed
Aug 19, 2015 04:52 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
