2k9 TB Adapater Plate
Has anybody developed an adapter plate that will bolt on the 2009 maxima throttle body to older 3.5 liter engines found in 02-08 maximas? The adapter plate should also work on G35s and 350Z.
So, I finally got the 2k9 TB on my 3.5 hybrid.
I redrilled the bolt pattern to match my '03 UIM inlet then opened up the inlet with a 3" 40 grit flapper wheel. The two bolts that go into the blind holes needed to be shortened since the TB isn't as thick in the bolt mounting area. And I had to re-do all the convert to cable b.s. since the electric motor side is different.
I'll get some more pic tomorrow when I've got some light.
Here's a couple pic of the bore matched:
That TB would be more useful if the OP removed the throttle blade, cut off the upper (unthreaded) half of the shaft, countersunk the blade and screwed some shorter flathead screws into the lower part of the shaft, and pick up about 10% more cross-section area in the bore. IMHO....
I did that to my other car. I'll probably do it to this one but you gotta remember cross section isn't everything.. that plate makes a pretty large boundary layer when fully open and half shafting won't do a whole lot.
It would be nice to have a way to flowbench an entire intake manifold/TB/MAF assembly. Anyway, narrowing a TB shaft is a "can't hurt - might help" mod for anything less than "all the airflow you can get".
stupid question but what size silicone couplers are you guys using for these 09 tb's?
no way in hell my 3" coupler is gonna fit on there. im about to just use the 4" one and lay a couple rounds of electrical tape around the TB
knight_yyz
Nov 1, 2015 01:34 PM
