Sponsored by:
Sponsored by: CARiD
Crank Balanced
Old Oct 1, 2012 | 04:47 PM
ALTIMA VQ35's Avatar
Question Crank Balanced
Hi guys
i have VQ35 and I bought CP pistons 11.0 CR
with eagle rod , the Question is do i need
Crank Balanced or not ?
thanks
Old Oct 1, 2012 | 06:53 PM
grey99max's Avatar
LandShark has Cosworth
Originally Posted by ALTIMA VQ35
Hi guys
thanks
IMHO, Simple answer - yes. When you change the weight of reciprocating parts, you gotta re-balance the rotating assembly. The engine will live much longer - and run smoother as well.
If you need to convince yourself, weigh the pistons/rings/wrist-pins separately from the rods and rod bearings, and get the OEM weights of the same parts and compare them. If you're lucky the parts will have identical weights and you don't need to re-balance anything. Otherwise, get the engine balanced.
Old Oct 2, 2012 | 05:30 AM
Maximeltman's Avatar
will even a few grams of weight difference have drastic effects if not rebalanced? like if the OEM piston weighs 93g and the CP pistons weigh 90g, and it goes together without balancing, will this be very bad for the engine?
Old Oct 2, 2012 | 06:34 AM
grey99max's Avatar
It's your engine - you get to decide. A quick conversation with your engine builder will be the best way to answer your question.
Old Oct 2, 2012 | 07:32 AM
Kgkeen101's Avatar
I went to high compression and rebalanced. The engine builders told if I went from 11.1 to lets says 8.5 to 1 and went lower with weight then it is okay to be overbalanced. Not good to be underbalanced though. That is coming from Total Engine Concepts in West Palm
Old Oct 9, 2012 | 11:18 AM
thanks guys , I really appreciate it
Old Oct 15, 2012 | 08:28 AM
FastnFuriousMax's Avatar
11.0 is really mild. any reason you didn't go higher? it really doesn't add hp anyways so I guess it doesn't matter...
and yes i would balance the entire rotating assembly.
TKHanson
Nov 24, 2018 01:39 AM
chisam14
Nov 6, 2018 08:56 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
conansriver
Sep 11, 2015 10:26 AM
