3.5 swap starting problem. Need Help!
I recently installed a 3.5 in my 4th gen. I've checked spark, it's there, checked grounds, crank/cam sensors are not throwing codes, I have fuel pressure. The car turns over all day, and begins to start but dies quick with starter fluid. I'm using dek fuel rails and injectors, using the stock fpr. I'm also using a stock tb converted to cable. We soldered the injector connectors, but we cannot tell if fuel is coming out or not. Is there anyway to tell if fuel is coming out of the injectors? Will the vacuum lines cause the car not to start? I could greatly use some advice! Thanks
Fakie J Farkerton
Oct 14, 2015 06:25 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
