Sponsored by:
Sponsored by: CARiD
6 SPEED swap question
Old Oct 27, 2014 | 03:50 PM
Blackwind's Avatar
the old thread is closed, but i need some serious clarification...the transmission mount, is the only one that can be used to mount the trans the SILVER one, or do you HAVE TO use the black one that gets modified to the fender?
Old Nov 19, 2014 | 09:52 AM
vipervadim's Avatar
I like Maximas
Yes, you have to use the Black 6spd mount that bolts to the frame.
you also have to cut off the factory 'ear brackets' for the auto/5spd mount to be able to position the 6spd mount on the frame in that spot.
only 02-03 Maxima 6spd mount will work, the maxima 04+/sentra se-r/altima se-r mounts are different.
You CAN make a custom mount to bolt onto the 6spd reusing the 5spd/auto 'ear brackets', but the factory 6spd mount is a better/stronger mounting option.
Old Nov 19, 2014 | 12:22 PM
Blackwind's Avatar
roger that
Old Nov 29, 2014 | 06:57 AM
aackshun's Avatar
I've answered this a few times and on my blog iirc.
You can use ANY Maxima/Altima 6mt mount and bracket.
But you must use the SAME mount and bracket.
EG. 02 Maxima Mount and Bracket will work fine. 04 Maxima Mount and Bracket will work fine. 06 Altima 3.5 mount and bracket will work fine.
But DO NOT mix the cars eg. 02 Maxima bracket and 06 Altima mount. You will have problems there.
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
