Sponsored by:
Sponsored by: CARiD
5.7 gen datalogging wideband
Old May 26, 2017 | 09:28 PM
freezer's Avatar
I am working on my 5.7 motor swap and am looking at wideband options for when I do more bolt-ons. I don't intend to use a piggyback (ECU reflash instead) so I am investigating my options. I have read quite a bit and I understand the principles behind tubing but I'm not experienced. I need to be able to log; RPM, AFR, timing advance. I think it would also be beneficial to be able to see injector duty, MAF, IAT, TPS, load, VSS, APP and maybe cam timing.
At the top of my list are:
AEM X-Series OBDII with Android app. $225 single
Zeitronixs ZT-2 with nDash (also OBDII). $799 single
iDash by 14point7. Cheapest 2 bank option but data logging looks cumbersome and would require splicing. $299 ($399 dual)
Wondering what others think. At this point I don't intend to permanently install a gauge anywhere in the car so aesthetics aren't really a consideration. My only other concern is I am not sure which PIDs the 5.5 ECU supports, I guess I should throw a battery in the car (no motor ATM) and find out.
Edited with prices and more specific Zeitronix option. It looks like AEM is a winner at this point.
Old Jun 8, 2017 | 09:04 PM
T00Lbox's Avatar
Someone correct me if I am wrong....
NissanDataScanII - About $60 If I remember correctly
Innovate LC-2 wideband - $155
USB to serial adapter for LC-2 to NDSII - $12 (One with FTDI chip)
Cheap OBDII to USB cable - $10 (If you are reflashing the ECU yourself then you already have this)
You can log everything to NDSII on a laptop and not have to bother with the wideband gauge if you wish. Might not be what you're looking for, but its another option.
Old Jun 14, 2017 | 09:18 PM
freezer's Avatar
Thanks, I wasn't aware of this and am going to test it out too!
I hooked up power to my ECU (still not ready to put my motor in) and checked the PIDs available via Torque. I'm rather pleased, the only items I don't see which I was hoping to are APP and IVT advance. Tomorrow I think I'll play around with some data logging in my truck to see what kind of resolution is possible. Looking like AEM will be my choice.
Attached Thumbnails 5.7 gen datalogging wideband-screenshot_20170614-210836.png
