urgent...need help quick?
Old Dec 9, 2000 | 11:19 AM
93 SE's Avatar
about to change speakers...3rd gen bose....thers 4 wires goin into bose amps,black,red and 2 others,which ones do i use to hook up new speakers
Old Dec 9, 2000 | 01:13 PM
Surge Diesal
Are you using the BOSE amp, throwing in a new one, or hooking the speakers up to an aftermarket deck. I never messed around with the BOSE but assuming all things equal; black is ground, red is power, and the two others should be the source inputs. What I'm getting at is that the speaker wires are coming off the back of the deck, in which case you can just hook up the speakers using the wires available at the source. If there are really only four wires to the amp then the source inputs are probably signal outputs, in which case you can use those. Confused?
Old Dec 9, 2000 | 01:14 PM
Surge Diesal
R U sure theres only 4 wires?
Old Dec 9, 2000 | 03:34 PM
Ryan93SE's Avatar
when i did this there were 4 wires...
the two SMALLER wires are the speaker wires... the two bigger ones are the wires going from the amp..... cut the smaller ones and hook those up to the speaker... i cant remember which colors are what... just try them both and see what will work
Old Dec 9, 2000 | 08:07 PM
93 SE's Avatar
lookin at a speaker...theres the speaker,then from speaker r 2 wires from bose amp... now from amp theres 4 wires connected to it in a clip harness,which comes from headunit...im putting in an aftermarket deck...so now i wanna know outta the 4 wires is the red,black for amps power or for speakers/pos,neg
Old Dec 9, 2000 | 08:17 PM
93 SE's Avatar
ps.. im not using the amps just wanna use the wires instead of running new ones...and whats the deal with my antenna jack that plugs into my new deck..its got 2 little things stickin out instead of a normal plug that should just go in my radio ...i didnt do front doors yet ..can i just drill new holes to fit 6 1/2s in or do i gotta build somthin
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
