Fronspeaker box
Old Jul 16, 2002 | 03:38 PM
Canuck's Avatar
Fronspeaker box
Does anyone have instructions on how to make speaker boxes for the front doors which will fit 6 1/2 speakers.
By the way I already searched and couldn't find anything.
Old Jul 16, 2002 | 03:53 PM
jmax
The problem with putting a box behind the front speakers is that the window rolls down too far. I think Whitemax turned his map pocket into an enclosure for his Dynaudio MW170's. Are you still in Canada? You should drive down to the states. We could build it here. But most car mids are designed to work in the leaky sealed environment of the car door.
Old Jul 16, 2002 | 05:06 PM
Nismo's Avatar
sweetsound made wooden enclosures for the fronts. he has a write up somewhere
Old Jul 16, 2002 | 06:16 PM
Canuck's Avatar
I realize this, I am just trying to get better sound without buying new speakers.
Old Jul 16, 2002 | 06:17 PM
Canuck's Avatar
Anybody have a link?
Old Jul 16, 2002 | 06:25 PM
jmax
I am pretty sure Anton just used MDF for the baffle. Like most of us, except mine is birch plywood. The frame for my baffle is glass. But it still vents into the door. A barrier along the window rails would need to be inserted in order to build an enclosure in there. But the new baffle and a well sealed door is what causes the most dramatic change in SQ. Along with generous dampening material. Sweetsound has a page on sounddomain.com. I don't have the link handy, but he posts it often enough that it should be easy to find.
What drivers are you using in the doors?
Old Jul 16, 2002 | 06:29 PM
Canuck's Avatar
I have eclipse point source with power by a V12 sending about 100rms a side. I do have some sound deadening material, but I am always looking for cheap ways to get better SQ.
Old Jul 16, 2002 | 06:38 PM
jmax
A solid mounting location with good seal is a great start. Are you Stephen Naryan? Or are there now two Canuck's?
The solid mount can be wood, glass - or other composite, metal, whatever. The seal has nearly infinite possibilities as well. Dampening material can serve this purpose in a bind.
Old Jul 16, 2002 | 06:45 PM
Canuck's Avatar
I am the other canuck, the original
Old Jul 16, 2002 | 07:04 PM
jmax
Okay, Stephen is a member of teamamp and recently swapped out some phase linear aliante subs. I have no idea what anyone would swap those with. They are probably only out-priced by the old Velodyne's. But the Vel's are now only available used. The other thing is that I think he's already done a lot of the things you asked about, thus my confusion.
Old Aug 16, 2002 | 08:24 PM
SWEETSOUND2001's Avatar
Directions
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
Stagnet04
Sep 14, 2015 11:28 PM
