Add a set of subs to my bose stereo?
Old Dec 10, 2000 | 07:18 AM
CoOlKidS1979's Avatar
Can any of you guys help me out here. I want to add some subs to the factory bose system. Is there any way to somehow splice into the signal from somewhere in the trunk, also is there any way I can power the amp from a source somewhat close to the trunk, so that I can save time and not have to power the amp from under the hood? I thought there was something about this under the faq but i guess not?
Old Dec 10, 2000 | 04:38 PM
Surge Diesal
There are signal adapters that will allow you to hook up RCA's into the speaker wires from the trunk. You need to buy an adapter for ~$20 from an audio store and simply splice it into the speaker wires for the rears. I have done this before to quickly test subs and there is definetely a difference from using a full RCA setup. You will in all likelyhood have to run a power from the battery which includes a built in fuse somewhere along the line, but you can ground it anywhere to the metal bed of the trunk. Good luck.
Old Jan 1, 2001 | 05:49 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
You will need to splice off the speaker wires on the back speakers and run that to a converter which will convert it to the correct Ohm rating for the subs. You will have to run a power wire from the battery though.
________
LIVE SEX WEBSHOWS
9aj9
Apr 5, 2020 12:11 AM
popdedop
Sep 11, 2015 11:17 AM
