Will this mix?
Old Jul 18, 2002 | 08:36 PM
WindFall's Avatar
Will this mix?
k, i'm about to hook up my 2 12' infinity perfects in a sealed box. My question is, will the factory bose system match well with them, or will i need to replace with something better? I'm worried about the amount of treble with the bass, i.e. will the treble be enough to hear over the bass, according to volume level.
Thanks,
Wind
Old Jul 19, 2002 | 06:06 AM
slickonetoo's Avatar
Re: Will this mix?
Thanks,
Wind
generally, subs are a lot less effecient than your high's.subs need power to get excursion which is what you want for subs..More than likely you would need to replace your highs as well to match the subs as far as output...but the only way you can tell if you like it or not is to try it...you may or you may not...I'm not really a basshead but like for it to be there...I could get by if it was 1 10 or 12 but not 2...you just have to see if it sounds the way "you" want it to really
Maximan190
Dec 16, 2015 06:01 AM
msellas
Sep 23, 2015 09:16 PM
pjgreek
Sep 9, 2015 09:30 PM
Maxboy23
Sep 4, 2015 06:04 PM
