which is negative and which is positive?
Old Jul 22, 2002 | 10:30 AM
poorcollegeboy's Avatar
this sounds like a dumb question but i searched on the forum and went to several audio places and got different answers.
i have the infinty kappa 62.5i and 693.5i. they both come with crossovers. each crossover has 2 wires coming from the amp on one side and 4 wires going out into the speakers.
here's the problem. i know that generally the wire with the stripe is the negative wire. however, on the crossover the striped wire is connected to the larger connector that goes onto the speakers (which is positive). there are solid black wires and black wires with a white stripe. which is the negative/positive one???
i'm new to this.
Old Jul 22, 2002 | 11:04 AM
jmax
It does not matter which wire is used for positive or negative. The wire is the same, plain old copper either way. The crossover connections should be labeled, and you already indicated that you know which connector is pos/neg on the speaker.
Old Jul 22, 2002 | 01:59 PM
i understand this but here's a more detailed description of the crossover:
- 2 wires are permanently fixed on one side of the crossover - black wire and black wire w/ white stripe. these wires are to be hooked up to the amp or stock speaker wires
- 4 wires are permanently fixed to the other end of the crossover. they are paired in 2 and are all of different sizes. again there is 2 black wires and 2 black wire w/ white stripe.
- here's what's confusing me. the black wire w/ white stripe is connected to the POSITIVE terminals of the speakers (they are sized only to fit the right terminal)
does this mean that i hook up the black wire w/ white stripe to the positive stock wires? b/c from my understanding, the wire w/ the stripe is usually the neg wire. thanks!
Old Jul 22, 2002 | 02:56 PM
Gates's Avatar
Re: .
It doesn't matter what kind of stripe is on the wire. If the wire with a white stripe is already hooked to positive on one end, hook it to positive on the other end too. Wire is wire, the stripes and such are just guides so you don't accidently mix up the polarity.
gavin68
Sep 18, 2021 12:36 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
