Alpine CVA-1000 Lock deactivation?
Old Aug 6, 2002 | 10:31 AM
BBaker025's Avatar
I just won a Alpine CVA-1000 on ebay that I play on hooking up to my alpine nav. system and PS2. I think it might have a lock on it so you cant play ps2 while the car is moving. Can anyone verify if the CVA-1000 has the lock? If it does how can I deactivate it?
Old Aug 6, 2002 | 04:11 PM
BBaker025's Avatar
anyone?
Old Aug 6, 2002 | 05:10 PM
TimW's Avatar
The silent but deadly Moderator
I'm sure it does.. I think they have for 2 years
back to ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1371490144
I assume you mean you have a 1003...
Old Aug 7, 2002 | 05:59 AM
BBaker025's Avatar
I bought a 1000 here is the auction I won. here
Old Aug 7, 2002 | 10:21 AM
Gates's Avatar
I'm pretty sure that the 1000 model doesn't have the e-brake protection. That's the reason why there is no bypass switch available. If you do a search on ebay for alpine bypass you'll see that those switches are for the 1003 and later. Even if you do need a switch, all you need to do is go to RadioShack. The instructions for how to hook one up can be found easily online.
Old Aug 7, 2002 | 12:54 PM
GndPrx's Avatar
The CVA1000 should have a simple ground wire that will allow it to display video without the e-brake on. I believe that it was designed to ground when the break is pulled, so just ground it outright and you should be fine.
I'm working off memory here though as it's been about 4 years or so since I've installed a CVA1000.
Hopefully I'm not sending you on a wild goose chase
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
ajahearn
Sep 19, 2015 03:03 PM
johnaschon
Sep 14, 2015 04:29 PM
