engine noise at highway speeds
Old Aug 9, 2002 | 07:31 AM
Speebs's Avatar
I aim to misbehave.
Hey all -
Recently, I noticed that when I listen to the radio and I'm going fast (50+), and I lightly press on the accelerator, I can hear a "popping" static-y sound from the speakers. This doesn't happen if I'm using the CD player/changer and at lower speeds the sound is perfect - and it's fine when I am doing real acceleration or when I'm coasting. The problem only seems to occur when I barely press the gas, like when I'm maintaining my speed on the highway. I don't think it is a new problem, because I never EVER listen to the radio (so it's not terribly important, either), but it is very annoying when I do actually listen to it. The popping does seem to be related to RPMs.
Last, and not least important, I do have a switch to put the antenna up and down. But all of the connectors are good, and if I bypass the switch it still doesn't work.
What do you think; bad ground? That's all I can come up with.
Please help!
Thanks,
Doug
captchaos
Mar 15, 2016 12:18 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Max139617
Sep 6, 2015 06:02 PM
jfl330
Sep 4, 2015 01:44 PM
