Check this out guys !!
Old Aug 15, 2002 | 07:50 PM
WaydeMax's Avatar
http://forums.maxima.org/showthread....5&pagenumber=1
I don't know how many of u have seen this. But it's about a improving ground wires in our cars ( as well as any others ) to improve various things, electrical and performance. I'm interested and will probably buy it. Is it legit?
Old Aug 15, 2002 | 08:54 PM
mb1's Avatar
mb1
Old Aug 15, 2002 | 09:06 PM
WaydeMax's Avatar
Old Aug 15, 2002 | 10:29 PM
jmax
Originally posted by WaydeMax
Kevin,
We should be able to do this ourselves for between $10 and $25 dollars retail when you come out to build your kicks. Maybe a little more if you opt for a "pretty" battery ground terminal.
Old Aug 16, 2002 | 05:38 AM
WaydeMax's Avatar
Originally posted by jmax
Kevin,
Hey, the money is right. We can do that if we have the time.
Old Aug 16, 2002 | 07:09 AM
Vadim's Avatar
Re: Check this out guys !!
well, at least if you have a big stereo system, you should have a thicker ground. I am running a 2 gauge to the trunk and my ground is a 0 gauge wire.
Old Aug 16, 2002 | 08:21 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: Re: Check this out guys !!
Ummmmm WHY????? Please enlighten me.
--Don
Old Aug 16, 2002 | 09:52 AM
Vadim's Avatar
Re: Re: Re: Check this out guys !!
--Don
simple current draw. If you are drawing a lot of current through your positive wire, then you should have a matching or bigger ground
Old Aug 16, 2002 | 10:02 AM
jmax
--Don
Factory ground in the 4th gen maxima, from chassis to block is a flimsy 4 gauge wire. Same for the wire running from the chassis to battery terminal. Our cars have polyurethane engine mounts. So no current flows from the block to the chassis except through the ground wire. But I can't see any way that this would improve performance or gas mileage. That's like saying $20 spark plugs burn more fuel than $10 spark plugs.
Old Aug 16, 2002 | 10:15 AM
Pearl96Max's Avatar
Re: Re: Re: Re: Check this out guys !!
O I understand current draw, and yes it is simple. Althoughwould you water your grass through a garden hose, with a fire hose as an extension?? Would you get the same pressure/continuity? No. Your ground wire should be the same as your power, not larger, but the same.
--Don
Hey James..some feedback on this??
Old Aug 16, 2002 | 10:21 AM
jmax
Re: Re: Re: Re: Re: Check this out guys !!
Normally the ground wire is shorter than the power wire. So it does not need to be as heavy or thicker. But it should be up to the current demands of the system. I have over 1k watt RMS now class AB. And a couple big class D's in my basement. My system is wired to be able to hook up a few k-watts.
--Don
Old Aug 16, 2002 | 11:15 AM
Vadim's Avatar
--Don
i agree, but larger ground shouldn't hurt it either and it looks cool
Old Aug 16, 2002 | 11:20 AM
Pearl96Max's Avatar
Re: Re: Re: Re: Re: Re: Check this out guys !!
Ummmm Ya forgot to type something !
--Don
BTW when ya coming up for that BBQ thingy? You can uhh help with a lil something I wanna do.
Old Aug 16, 2002 | 08:42 PM
Sin's Avatar
Sin
You do know that for the system you are running, the wires you use are WAY overkill. You are getting ZERO gains in output for the current you are drawing.
Old Aug 16, 2002 | 11:59 PM
jmax
Re: Re: Re: Re: Re: Re: Re: Check this out guys !!
--Don
*%$*^#*#* Sorry, I typed but didn't realize until I hit the submit button that I was inside your quotes. It just doesn't look like I typed anything. *$^*&(*#&&
I gotta look at the calendar. I sorta made plans for Monday night. Gotta get hammered with a co-worker. Sometime between now and then we have to decide who's drivin / payin for the cab. And I would have to dig the tent out of the garage. It's kinda buried behind MDF, BB, dmpening material, wires, speakers, etc.
Old Aug 18, 2002 | 03:15 PM
ThumpinMaxima's Avatar
i wanna bbq
Old Aug 18, 2002 | 09:45 PM
Pearl96Max's Avatar
Originally posted by ThumpinMaxima
i wanna bbq
sure why not, but it looks like quite a ride for ya just for some good cookin'
--Don
Old Aug 19, 2002 | 07:19 AM
Vadim's Avatar
not really, I am running 2 kicker zr360, those things draw a lot of current. Each one of them got 2 40amp fuses
Old Aug 19, 2002 | 07:23 AM
Vadim's Avatar
plus I get wiring for dirt cheap right now, so I went with a little bigger one in case I want to upgrade my setup in the future to smth even bigger
JMag90
Aug 25, 2015 09:17 AM
raffivegas
Aug 23, 2015 09:54 PM
maxipower
Aug 21, 2015 11:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
