Trying to install SUBS on bose system
Old Aug 19, 2002 | 06:21 PM
PicktownMaxima's Avatar
I just got a 1997 Maxima GLE with a BOSE sound system in it and i want to install my system in but i can't find the wiring colors for the BOSE sound system. Anybody know the wire colors for the rear speakers?
Old Aug 19, 2002 | 07:38 PM
Maxima Dan's Avatar
What exactly are you trying to do? I can probably help out, but I need more info. Are you just trying to hook up an amp and some subs to the stock head unit, or are you trying to amplify the stock speakers with an aftermarket amp... You should just buy an adapter for the stereo wiring harness, makes it much cleaner.
Old Aug 19, 2002 | 09:08 PM
I'm hooking up a amp and two 12"subs and i need to know which wires are for the rear speakers.
Old Aug 20, 2002 | 08:25 AM
Sprint's Avatar
check the FAQ's in the 4th Gen Forum..
http://forums.maxima.org/showthread....0&pagenumber=2
Old Aug 20, 2002 | 12:28 PM
Maxima Dan's Avatar
You will need to convert the signal coming off the headunit. It is not speaker lever, or line level, it is balanced. Several companies make converters...check out audiolink. I think it is audiolink.com. They also have a lot of adapters and information.
Good luck.
Old Aug 20, 2002 | 01:29 PM
Sprint's Avatar
Good luck.
I disagree.. you can run the leads from the Bose Speaker minus the Amp stright to the line inputs of the sub amp.. my cousin had it running for a while.. he didn't need any adapters
Old Aug 20, 2002 | 03:49 PM
Triple8Sol's Avatar
I miss the .org!
Good luck.
I tried audiolink.com and audiolinks.com, but neither was it...do you know what the right web address is?
Old Aug 20, 2002 | 03:59 PM
Maxima Dan's Avatar
Sorry, try this
http://www.linkmeup.com/
MikesChevelle
Nov 23, 2024 11:17 AM
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
Maxinesdaddy
Aug 21, 2015 11:43 PM
