tri-way crossover problems
Old Aug 28, 2002 | 01:18 AM
pinakbet's Avatar
Hi all,
Here's the scenario:
I have a 6 channel amp. 4x75 + 2x150(bridged) I used a pair of Line-level converters to hook up RCAs to stock 5thGen HU(non-bose). I installed a 3-way crossover(passive)that runs the rear speakers and sub.
All the wiring is correct, but the sub does not work. The only way I can get any sound out of the sub is if I move the RCAs around so that Fader and Balance controls are switched. ie, i use the fader to pan left and right, balance to fade front to back. Setup this way, everything sounds fine except the sound stage is rotated to the right 90degrees.
I have to add that for the Line-level converters, instead of wiring the convertors left and right for both the front and back, i wired them front and back for the left and right. Did that make sense? I suspected this, but a signal is just a signal right? I dunno. That's why i'm here asking... Any ideas as to what's going on in my setup? Should i just give up and return the crossover and perhaps get a 2nd amp for the sub?
Thanks,
Bryan
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
homewrecker
Sep 24, 2015 07:01 PM
